Old 10-19-2023, 07:14 AM   #1
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Solid roller N/A SBE hit 605rwhp on the roller
Very happy about the setup and ultimately, having a real number after last dyno when the rpm signal was skewed and the run was cut around 7k and the numbers were still climbing but the run stopped (568rwhp). I upgraded the exhaust to a full 3'', X pipe and Z28 mufflers since then.
I finally hit the rollers and this time the rpm signal wasn't acting up like last time.
MODS
Solid roller N/A,
Cam Motion low lash no fly cut 239/253 720' 702'
T&D 1.8,
Smith Brother custom pushrods (very short like 6.8ish), 1530 PAC springs,
Isky rev extreme linked lifters
stock SBE 50k miles,
RPS twin,
James Goertz custom fit manifold intake,
102mm TB,
EWP,
2" SW LTs& HFC, 3" exhaust Xpipe into Z28 mufflers, forged 19" wheels,
wildwood rear drag brakes,
FED TFS custom heads,
11.33 CR, 91oct,
Pat G Tuning remote tune with no wideband,
Vararam VRX with green air filter,
JRE scoop,
short belt mod,
Fluid damper,
Zrod 10w30 oil.
A full bottle of VP oct booster 1/4 tank of 91oct.
Work done by me.
Thanks to my crew for all help and advices:
Tyler for the cam!!
Phillip Green
Doug Clark
Zack
Aaron Popp for the logistik haha
And all other involved, especially my wallet who suffered a lot
605rwhp with the sae correction. 622rwhp uncorrected, air was good; 0.974 correction factor.
I did 595 engine hot, then let it cool and removed the AC belt then did 605rwhp!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 10-19-2023, 11:10 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Nice!
larry_g is offline   Reply With Quote
Old 10-20-2023, 10:51 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Holy cow man, that's awesome!! Well done sir!!
Old 10-21-2023, 07:45 AM   #4
Bo White
Bo White's Avatar
Awesome to see outcome of builds
Totalled:
Old 10-21-2023, 08:02 AM   #5
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
awesome!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 10-24-2023, 02:24 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Oh hell yeah!
I have a question though on that mammoth cam lift. Those cam lift numbers are NOT factoring in the 1.8 ratio rockers, right?
Either way, that's insane and we need to hear this! I love these sick solid roller builds. Congrats!
InFiD3ViL is offline   Reply With Quote
Old 10-29-2023, 10:23 AM   #7
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Originally Posted by InFiD3ViL View Post
Oh hell yeah!
They do factor the 1.8 Its around 690 lift cam if 1.7 ratio.
13' 1LE
Old 10-29-2023, 08:56 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Youtube video link
https://youtu.be/dp8DSv2HsD0?feature=sharedhttps://youtu.be/dp8DSv2HsD0?feature=shared
13' 1LE
Old 10-30-2023, 06:30 AM   #9
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Sounds great - love that music of an LS approaching 8000rpm.
