10-17-2023, 09:43 AM | #1 |
Drives: 2020 2ss Join Date: Sep 2023
P0446 CEL - EVAP System
I've replaced the vapor canister vent solenoid after this code popped up. Reset the ecu, CEL went away. CEL / Code came back after 80 miles ~ 48 hrs.
Has anyone had success combating this code? I didnt see much success in the old threads. I heard the gas tank filling inlet seal can be an issue? Mine doesnt screw on its just a flap. ACDelco 22740537 GM Original Equipment Vapor Canister Vent Solenoid https://www.camaro6.com/forums/showthread.php?t=529855 2020 camaro 2ss |
10-17-2023, 12:44 PM | #2 |
This is a pretty good explanation of the code and related vehicle function:
https://www.samarins.com/diagnose/p0446.html I suppose the first thing which might help is to figure out when it is setting the code. Is it during the pressurization (leak) test or during a purge cycle? Any right rear wheel well area damage that might have affected charcoal canister or vent line? Here's an old post of mine which describes the location of some components. There is a filter on the vent line. https://www.camaro6.com/forums/showp...9&postcount=12 |
11-29-2023, 01:41 PM | #3 |
ctrlz Thank you!
Evap pressure sensor needed to be replaced. Under the rear passenger wheel, T'd off to the pressure line. |
