10-17-2023, 12:21 AM | #1 |
Drives: 2019 Camaro Convertible Join Date: Oct 2023
Various Electronics failures, just sensors or more going on?
Hi all, I have a 2019 Camaro Convertible LT 4 cylinder. I'm boring, I know :P
Recently I've been having various issues that all seem to be electronic related and I just want to see if anyone has any thoughts other than "pay the dealer lots of money". Issues in order of discovery:
Every local mechanic I've called has said I need to talk to the dealership, which I believe. I just don't know if it's these sensors that need replaced or something more systemic. Thanks! |
10-17-2023, 07:45 AM | #2 |
to the forums, and no, you're not boring at all
I'm not a mechanic, but the first thing to check is proper voltage, ie the battery and ground cables. The computer modules in your car are very sensitive to intermittent low voltage conditions and can produce any spurious errors. If that is ruled out, it's still very unlikely that completely unrelated parts would go bad at the same time. Or did you just buy the vehicle used and are now discovering its issues? Any further diagnostics will require a proper scan tool and/or the service manual, which is a decision point for you, ie it's matter of whether to invest and try to fix it yourself, or throw in the towel and take the car to a proper mechanic, be they at the dealership or elsewhere. Re the key fob, its CR2032 battery could also be on its way out, it's very cheap and easy to replace and check if fob recognition improves. The cupholder "trick" (guess that's what you refer to by "transmitter pocket") is meant to allow you a few more starts when the fob battery is nearly dead and is basically a gentle nudge to replace it.
10-17-2023, 10:35 AM | #3 | |
The issues all started happening recently, in the past 6 months, but not all together. I have replaced the battery of both key fobs twice. According to what I read elsewhere (and have done myself) the cupholder trick will work even without a battery in the fob. It seems statistically anomalous that both fobs would die at the same time, but weirder things have happened. I don't have any of the proper tools, so I guess it's off to the mechanic for me. |
10-17-2023, 09:08 PM | #4 |
Looks like the voltage is hovering between 12-14 volts. I assume that means the battery is on its way out. But I'm not sure if that would cause any of these other issues.
10-17-2023, 09:41 PM | #5 | |
I bought a midrange scan tool and a battery tester for myself, but they're probably not worth getting in your situation. Good luck with the professionals, hope they'll be able to figure it out, and please post up the outcome, if only for our information
10-18-2023, 07:54 AM | #6 | |
Thank you Al Oppenheiser!
That being said, I have seen this error in my car (along with several other random CEL codes: service stabilitrack, etc.) at the first restart after the battery died. Clearing the codes with a cheapo OBD2 scanner resets the error. Have not seen it come up on its own in my car (yet), so in my case I believe it to be a faux-fault and random module glitch due to the low battery voltage -- also common on our cars. Since your issue is recurring, you may need to have the gear selector assembly repaired (faulty internal switch identified and replaced), or entire assembly replaced. Might be worthwhile to have an automotive electrician who is familiar with GM "shift to park" issues check the relevant circuits of your faults ... in case they happen to share a common wiring. Gear selector work ain't cheap (IIRC the trans has to come out), so it might be worth a couple hundred bucks for a complete diagnosis. |
electronics, key fob, push start |
