10-15-2023, 11:29 AM | #1 |
Drives: '12 2SS 6MT Join Date: Mar 2023
Suspension mods for autocross, where do I begin?
Trying to decide between getting pedders sway bars or BMR 1.25 lowering springs with eibach struts as a little holiday gift to myself, which would have a bigger impact on autox times since the prices aren't that far off? Currently on stock FE4 suspension with a 275/315 staggered setup, and it understeers on the 180s way more than I would like. I know biggest mod is the drivermod but I wanna upgrade the car while I'm working on that too.
Cold Air Inductions intake w/ race scoop, Borla ATAK Catback, EBC Yellows & RBF 600, BMR strut brace, Z28 replicas, Factory Hurst Shifter
10-15-2023, 08:07 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
An adjustable rear bar will give you a way to tighten the rear end and bring the balance more neutral.
12-13-2023, 07:06 PM | #3 |
Drives: 2012 Camaro 2SS Join Date: Jun 2023
I'm right there with you. Did a track day in October and learned just how bad the under-steer is on mine (aftermarket wheels but with factory 275/245 staggered setup). I've bounced off of every wall trying to decide the best course of action. Just too many options. I've considered just throwing the kitchen sink at it, then reeled myself back in to something a little more conservative to start with while I, too, work on my driving. I'm not trying to build a racer-car, but do want to make some improvements to maximize my fun time at the track.
Before my next outing I'm going to put an adj rear bar on it and it'll be on a squared 275 or 285 setup using dot/track 200tw tires. |
12-14-2023, 07:09 AM | #4 | |
GPI Sales Consultant
Got a question about a GPI product? Feel free to shoot me a message! |
12-14-2023, 09:17 AM | #5 |
Your tire sizes aren't helping. 285 square or 285/305 is a better choice along with a performance alignment. Then hone your skills. Developing your driver skills is tough when you are parts swapping all the time.
Going bigger, the 1LE suspension, wheel and tire sizes and a bigger rear adjustable bar would be a nice setup. Solid rear cradle mounts (AFE/Pfadt) are a great upgrade too. As far a drop springs, they don't make as big improvements as people think other than looks. But a matched setup, with the drop springs and matching anti roll bars, goes along way to having a good baseline. Detroit Speed has drop springs and matching adjustable anti roll bars.
12-14-2023, 12:57 PM | #6 |
Drives: 2013 ZL1 Join Date: Nov 2018
Modding the car for track days or autocross does not do the same as modding the car for the drag strip.
You'll learn this the easy way or the hard way. Seat time makes you faster in these realms, not modifying the car. Put a square tire setup on it and learn that before any other changes.
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
12-28-2023, 03:40 PM | #7 | |
Probably going to do wheels/tires as my next mod, I bought the car with the current wheel/tire sizes on it, so that wasn't really my choice for the 40mm stagger. My current plan is to get a pair of 20x10s to match the rear and ditch the 9" wide fronts to run square 285/35 20, unless I can cram something larger up front but 285 seems like the go to.
04-01-2024, 10:51 AM | #8 |
Well I installed the 32mm Pedders rear bar under my car about a month ago and it definitely eliminated a lot of body roll. The car feels more neutral now but I have yet to push the car hard enough to see just how much. I have a track day in two weeks so I'll know more about it then. Since the staggered tire setup is my baseline I chose to stick with that for now, but I did move the 275/40's up front and got wider wheels with 305/35's out back, so I added 30mm of tire width to each corner. Theory there being, more overall grip but equally applied so it shouldn't mess with the actual balance a lot.
We'll see what the results are and I'll make a decision moving forward from there. |
05-01-2024, 04:44 PM | #9 | |
Did you ever make it out to the track and if so what were the results?
