10-11-2023, 11:39 PM | #1 |
I’m Magik a physco dog
Drives: '15 1LT/RS & '23 3LT/RS Join Date: May 2016
Adjusting speedo after tire change
Is there a way to adjust speedo to correct after tire change without using a full blown tuner that I would not use those other features it comes with.
What’s weird after checking the online calculators I should only be offf 1 mph at most, but my GPS radar detector shows when going 75 dash shows 71. I have staggered sizes 245/45/20F 275/40/20R Does the computer read the rear or front? Thanks.
2023 3LT RS Shadow Gray
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' |
10-12-2023, 06:29 AM | #2 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
10-12-2023, 06:50 AM | #3 | ||
Did you switch to a different tire brand and/or model, too?
10-12-2023, 10:10 AM | #4 |
That's a rather small change in aspect ratio It shouldn't be off my 4mph.
10-12-2023, 11:02 AM | #5 |
Any possibility new tires are overinflated?
Tire pressure will have an impact. |
10-12-2023, 01:25 PM | #6 |
Drives: 2023 Camaro LT1 M6 Join Date: Dec 2022
going from 245/40/20 to 245/45/20 goes up an inch in overall diameter from 27.7 to 28.7 which is 3.6% (and 275/40/20 also is 28.7) so doesn't seem surprising to me that you might see ~4% speedometer delta. As you went up a full inch in diameter - If you wanted more sidewall did you consider going to 19" wheels and you could have gone with 245/45/19 and 275/40/19 at the same 27.7 diameter to avoid speedo issues?
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers |
10-12-2023, 11:51 PM | #7 |
Hey all thanks for the reply’s and links, I tested the gps in another vehicle and a 1mph gps reading error does exist, that would leave me with a 3 mph error at my test speeds of 75 on gps reading 71 on dash bumping up to 76 gps reading showed 72 on dash then minus the 1 mph gps error leaves me with a 3 mph error in both speeds.
So being the reading comes from the rear tires yes that calculator gets me to the 3 mph and looking at that calculator reading of 50 actually being 52.8 and it’s rounding up to 53 on the dash now makes sense to me. Initially while driving and saw that large disparity I was concerned and TBH I never thought it be off by as much as the 3 I did change brands from the stock Eagle F1’s, As for the tire pressures it’s 35 all around, i didn’t see 19’s in the latest stock look 6th gen style so I stayed with the 20’s based on wheel style I was looking for. So there appears to be no way to correct unless going to a full blown tuner, I guess 3 will be a number I’ll get used to while driving. Here’s the new look, from the black wheels to these gunmetal gray.
2015 1LT R/S Blue Velvet Coupe. Previous: 2015 1LT Ashen Grey 2016 1LT Blue Velvet My entire life has been 'A Midlife Crisis' Last edited by Rob99; 10-13-2023 at 04:24 PM. |
10-13-2023, 04:23 PM | #8 |
I checked the speedo with speed signs in my neighborhood with cruise set to 25 the sign showed 27, 30 showed 32 same with gps
Comparing to the calculator the gps, speed sign and dash are rounding up.
10-27-2023, 02:10 PM | #9 |
Drives: 2021 Camaro 2SS Join Date: Oct 2023
I'm thinking of doing the same setup. Driving crappy roads through Philadelphia to get to work, I can definitely use more sidewall. The stock Eagle F1 ROFs are punishing. I can deal with the speedo being off but any issue with rubbing in the front?
10-27-2023, 08:55 PM | #10 | |
the ride is improved and they are much quieter than the RF's, plus i got a wider look in the rear which looks great, no rubbing at all. I changed the rims to accommodate the wider tires in the rear. I carry a Worx portable air pump and a tire plug kit, additionally i have AAA. Good luck with your swap.
