09-22-2023, 03:54 PM | #1 |
Big Gulp = CAI? Not so much..
So I'm in the process of routing cooler air to the TB by doing the ram jet snorkel, removing rain/snow backing, and improving the air let areas.
I was checking engine compartment temps as I always do and noticed that the outside face of the Big Gulp nearest the header gets to 115F. The inside face nearest the filter reaches 100F and the edge of the filter reaches 85-90F, etc., whereas the headlight side of the filter was nearer to ambient. So, I covered the outside of BG with DEI heat shield. The BG also did not fit the body panel or hood well, and there were gaps between the BG's pieces, so, I filled all those gaps with insulation. The BG surfaces now run much closer to ambient. I can already see improvement in IAT and MAT. The snorkel and headlight area work is next week. The point is, I was surprised that mine needed this rework. Your CAI also might not be as efficient as it could be.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
09-22-2023, 04:35 PM | #2 | |
09-22-2023, 06:21 PM | #3 | |
09-22-2023, 06:39 PM | #4 |
09-22-2023, 07:36 PM | #5 |
Did you read the part where I'm doing ram air snorkel and adding additional areas of air flow next week? We're saying the same thing. CAI is just one part.
'20 ZL1 1LE A10.
09-22-2023, 07:40 PM | #6 |
09-22-2023, 09:45 PM | #7 | |
…this is a serious possibility. I question the air filter size for two reasons: 1. Pray nets 35 WHP on a 930 WHP Camaro with simply removing the filter and adding a bell mouth. 2. I just put a nice CF Corsa CAI on my wife’s new Mustang GT and the filter they provide was bigger and better designed than the filter on my BG! My wife’s car needs 48 lbs/min of airflow…. I need 123 lbs/min of airflow… WTF lol So couple questionable filter size with a “box” area that’s choked for airflow and I think it helps explain why cars that dyno big numbers often struggle to get drag strip performance that lines up. I noticed Jason Leiva’s car does not run the heat shield at all! So it’s pulling in “hot” engine bay air…and trapping 173 MPH. Lesson learned!
09-23-2023, 06:26 AM | #8 | |
09-23-2023, 08:24 AM | #9 | |
I have a bell mouth which I plan to use at the track so I can determine if it alone helps. My goal is to run 8.9x but all the big hp gains have been made. The accumulation of a bunch of little gains should help me get there. That's why I'm doing them. Plus, I enjoy it.
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. Last edited by JSH; 09-23-2023 at 03:09 PM. |
09-23-2023, 02:37 PM | #10 |
Good write up.
09-25-2023, 12:08 PM | #11 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
I love the discussions on if RotoFab works and the importance of shielding filters, etc., all while we have been the quickest and fastest PD blown 6th gen for a couple years now doing this.
We did recently remove the headlight. I have no data to say if it helped, but we also just replaced the pictured intake with a larger 3D printed one with a larger bell mouth and picked up 1.5 psi even in 3300 DA.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
09-25-2023, 12:17 PM | #12 | |
'20 ZL1 1LE A10.
09-25-2023, 12:24 PM | #13 |
The inside diameter of that bell mouth and pipe is just 4.5".
09-25-2023, 02:04 PM | #14 |
How do you feel about running without an air filter? The dragonflies in Georgia can be huge!
'20 ZL1 1LE A10.
