Go Back   Chevrolet Corvette Stingray C7 Forum > Members Area > Past Camaro Fests > 2019 Camaro Fest (IX)
Old 09-09-2023, 11:00 PM   #1
Ricard350
Drives: 2019 ZL1 A10 in White Summit
Meticoulouly maintained 2019 Camaro ZL-1 door rusting...
---POSTED AT THE WRONG PLACE----
Found this today while I was wiping water inside the lower doors lip post washing...
I think this is unacceptable.
18 000km and never seen driven in the rain...
I suspect a bad seal at the seam.
The driver side is flawless...
What do you guys thinks? Am I the only one with this???
2019 White ZL1 A10
2007 Black HUMMER H2
2018 KIA CADENZA LIMITED --> Aparently rare AF in Canada
Ricard350 is offline   Reply With Quote
Old 09-10-2023, 02:35 AM   #2
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
No it is not in 2019 car.
I have seen that door rusting in 2010-12 cars.
Old 09-10-2023, 05:58 AM   #3
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Once they ship the 6th Gens to Canada they start rusting
Its the shivering
Seriously though that really sucks.
Have you had your dealer look at it?
Not that they would do much as they only cover rust through (holes) under the seven year corrosion protection.
On the positive side you caught it early and if you look after now it shouldn't cost much.
Old 09-10-2023, 07:23 PM   #4
xstuntman
Drives: 2012 Victory Red LFX
So you don't think it's seam sealer that got painted over?
Can't hurt to pump a a little bit of motor oil in those doors.
Messy maybe but rust is worse.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 09-29-2023, 07:17 AM   #5
Trickskier
Native Floridian
Trickskier's Avatar
Hope this helps you!
GM vehicles are designed and built to resist corrosion. All body and sheet metal components are warranted against corrosion for 3 years or 36,000 miles, whichever comes first. Plus you're protected even further from rust-through corrosion for a minimum of 6 years/100,000 miles (whichever comes first).
Old 09-29-2023, 10:21 AM   #6
chevy pilot
I was thinking exactly the same thing.
Has anyone scratched that there is actually rust under the paint or
would the paint have bubbled for another reason ?
Old 10-04-2023, 02:22 PM   #7
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
I had this on my driver door on my last 6th gen however I chalked it up to the driver door having had some form of repair done to it (according to the carfax and my paint gauge device). I had a body shop hit it with a wire wheel and paint over it. Fortunately it’s in the best location for a repair as no one ever looks down there and you don’t have to do any blending on adjacent panels.
Ever since this happened to me I now make it a habit to open all doors, hood and trunk to let any trapped water fall out so it doesn’t rust again. I bet lower mileage non daily driver cars are more susceptible to this as people wash them, only open the car door and pull them back into the garage for a day+ thus leaving trapped water in that area for an extended period of time.
Current: iso GT500
Prior:
2023 Camaro 2SS 1LE
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 11-02-2023, 08:55 AM   #8
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Sorry but this is unacceptable. Do your best to keep the car out of moisture. If you bought the car new, speak to your dealer for corrective measures, as you have a warranty against corrosion (although limited). First, find out if its actually rust. A lot of the time these cars come out of the factory rough, with particles cast inside of painted parts. If its not rust, then you shouldn't worry as it won't get worse (it doesn't look nice but if its not rust no one will care).
Obviously you need to keep the car out of moisture. Every once in a while spray on detailing spray, or spray wax, or spread wax on the sills and under the doors. Rely on my personal testament; It helps greatly.
Good luck.
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 11-02-2023, 03:56 PM   #9
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Pro body man, and I suspect that is seam sealer related and not rust. Only way to know is to poke through the paint and check.
Here's mine at 11 years, 7000k miles. Never seen rain.
chef-beavis is offline   Reply With Quote
Old 11-02-2023, 04:49 PM   #10
gtstorey
It could have been contaminated before painting and the paint bubbled. If it is on top of the primer it might be ok leaving it alone. If the contamination was before primer, it probably has some surface rust anyway.
Old 11-02-2023, 04:57 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I agree here, possibly. My Camaro is 12 years old with 129k miles. I do recall on one of my doors, and acouple other areas on the car I do have this same scenario. I was told that it is some seam sealer that had "squeezed" out from between the two panels when they were joined. I just left it alone because I was the only one who knew it was there. I live in Florida and she was a daily driver for 9 of her 12 years, and no rust anywhere..
Old 11-03-2023, 08:07 AM   #12
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Atleast you are smart enough to pull the door water drain plugs on a old car. Its amazing how much water can sit in the bottom of a door even after just washing it.
Bigdumogre is offline   Reply With Quote
Old 11-03-2023, 02:04 PM   #13
chef-beavis
No plugs on these, so no need to worry about that!
