#1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Android Auto Wireless and Galaxy Watch users, step into my office
Long story, long.
I have a S21 5G and a Frontier original - cannot use AA wireless with watch. reset phone and AA wireless works flawless on my S21 5G fast forward to now, have the same phone S21 5G and got a new watch 6 classic and AA wireless no longer works Anyone use both with success? If yes, what Phone? what Watch?
<Insert Cars You Own Here>
#2 |
![]() Drives: 2021 3LT RS A10 Join Date: Nov 2021
My pixel and Garmin watch combo work just fine in my car with AA
#3 |
AA Wireless?
#4 |
Hot Camaro
Fran, No idea if this will help you in your search for functionality...
But... I believe that the wireless functionality requires access to the BT in the phone at initial connection time for the car and phone to communicate and establish the "ad-hoc" connection required over WiFi for the high-bandwidth functions (things like maps and navigation, for example). Once the BT control has finished establishing the setup for the WiFi, it should change to a different BT mode for audio (phone calls, for example) and things like text messages. Your watch is BT-connected all of the time, and there's likely a problem with the phone shifting between the BT modes while keeping the watch connected. This could also completely by a Samsung thing as my Pixel 6 Pro and Pixel 7 Pro had zero issues with all of this while I had a cheap Amazfit watch connected, and I was using one of the third-party Wireless AA add-on dongles. It might be worth looking into various settings on the phone and the watch as well as possibly some of the automation software available for Android that you might be able to program to drop the watch connection while the car is connecting and then re-connect the watch (or similar). Have you tried restarting the watch while everything is connected to the car? How about trying to force reconnection to the watch from the phone with everything connected to the car? |
#5 | |
I use AAW a lot more than the watch so the watch can go back if necessary.
#6 | |
Hot Camaro
I do remember seeing something like that happen with my Pixels but it was a little different in that getting everything connected to the Camaro would wipe out connections to my truck and her SUV and vice-versa. It's -possible- that this is a stupid GM thing if that's the case - check for OTA updates for the Infotainment? |
#7 |
Hot Camaro
Are you allowing phone calls on the watch? Try disabling that function...
#8 | |
I am trying some of your suggestions and I have a post over at Android Help.
#9 |
Lol oops, yes AA wireless in my case, Fran.
#10 |
![]() ![]() Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
You'd be surprised. I think we had to update my wife's CX-5 8 times before every feature worked with her phone.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
#11 |
![]() Drives: '22 Camaro ZL1 1LE A10 Join Date: Jul 2021
I have a S22 Ultra and Galaxy Watch Classic 4. My AAW functions fine. When connected in the car, I get notifications on my watch and they show up on my headunit with Android Auto wireless. I have a '22 ZLE.
#12 |
![]() Drives: 2023 ZLE M6 Join Date: Jun 2022
When I am wearing my Galaxy Active2, my phone usually does not connect to the car for music. Kind of annoying, I have to disconnect and reconnect from my phone.
2023 ZLE M6 Borla S-Type Catback | Rotofab CAI | Soler TB | MPI Lid 2024 Polestar 2 AWD |
#13 |
![]() Drives: '23 2SS RSblue 6MT, sold '19 ND2 Join Date: Dec 2021
When I first got the car, wireless AA stopped working entirely no matter what, couldnt pair or anything. Onstar told me I needed a data package which was a lie. Coincidently this was right after Onstar trial for the data package expired. I had to factory reset the oem headunit and everything has worked well since.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars EOS front splitter 5-6-22:1100, 7-19-22: 3000, 8-3-22: TPW 8/15/22, 10-4-22: ETA 10/13/2022 10-15-22 6000 |
#14 |
![]() Drives: Camaro ZL1 1LE M6 Join Date: Mar 2023
I have a Samsung Fold 3 and and the Samsung 5 watch Pro. Having the same issues where AA doesn't properly work when using wirelessly. The occasional it does connect it will only stay connected for a short period of time, then it disconnects, and tell me there is too much wireless interference. I have given up at this point and just run a USB cord and plug the phone in.
ZL1 1LE
