Old 07-29-2023, 07:56 PM   #1
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Camaro in storage…Battery?
I’m looking to purchase a Camaro and where I’ll be storing it there are no outlets. How easy is it to remove and replace the battery so I can trickle charge it?
Thanks
2cnd chance is offline   Reply With Quote
Old 07-30-2023, 09:38 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Thanks
Open the trunk, remove the spare (if it has one). Remove the cables and battery hold-down. Out she comes. Nothing drastic.
Old 07-30-2023, 09:40 AM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Just don't close the trunk when you're done or you'll have to let the back seat down and then get a child to crawl through the tiny opening to pull the handle to open it back.
Old 07-30-2023, 03:08 PM   #4
2cnd chance
Thank you. The Vette is much more difficult.
Old 07-31-2023, 07:57 AM   #5
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Drives: Red Hot A10 ZL1 Convertible
Battery is easy to remove/replace.
Alternately, you can install a disconnect like this one.
And yeah, prop the trunk open or you'll need 12v power on the jump posts under the hood to push the button.
Gunkk is offline   Reply With Quote
Old 07-31-2023, 10:07 AM   #6
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Thanks
If possible, I'd look into an inexpensive solar powered battery maintainer. Might be less hassle than removing the battery...I've never used one, but they may be worthwhile....Good luck.
Old 07-31-2023, 01:45 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Remove the carpet, remove the battery well cover, it's held down by a big plastic knob, under there you will find a foam liner with an air pump, a can of fix a flat, or a spare if someone has updated that, remove it all, then disconnect the cables, hold down bracket, and you're done.
