07-24-2023, 09:33 AM | #1 |
Drives: 2020 V6 Auto 3LT RS Join Date: Apr 2019
Chevrolet Platinum Warranty Coverage Question
I have Platinum Warranty Coverage. There is a loud noise under the passenger seat when someone is sitting there. It sounds like a real shrill horn. I raised the seat and looked for anything blocking the parts that are there. I did remove a napkin, but that didn’t help. It is an intermittent noise.
I called the dealer and they said there would be a diagnostic fee if the warranty doesn’t cover it, they said they wouldn’t know if covered until they submit Is there any way to find out ahead of time if it’s covered? Is there a list of covered items some where? Thanks |
07-24-2023, 09:46 AM | #2 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
If you check your extended warranty paperwork, I believe it tells you what isn’t covered, so anything else should be covered. The dealer should be able to determine that before you take it in. My brother has had to show his dealership on two different claims that they wanted to charge him for. The warranty paperwork confirmed that if it wasn’t listed, then it was covered.
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
07-24-2023, 10:16 AM | #3 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
I have platinum coverage as well. Platinum covers almost everything except wear and tear items like clutch, brakes, spark plugs, etc. if you google “GM platinum coverage” you can find a list of exclusions. For example it doesn’t cover cats/exhaust even though that’s not a wear and tear item.
