dave@hennessey
Old 06-28-2023, 03:00 PM   #1
sinisterZL1
sinisterZL1's Avatar
Drives: 2014 ZL1 - M6
M6 to auto swap
Looking to swap the M6 for auto , sick of being slow on the 1/4mile track.
Is there a complete kit on the market? I don't wat to go to 3spd TH400 as i want to be able to cruise it as well as drag race it more.
Car is making 789WHP and 770Tq
sinisterZL1 is offline   Reply With Quote
Old 06-28-2023, 03:50 PM   #2
T-Type
Drives: Pontiac G8
I don't think I've heard of anyone wanting to change to an automatic. Usually it's the other way around. Though if that's what you want, I'm not here to judge. Why not find a used auto that normally comes with the car. They shouldn't be hard to find. It will simplify things though it still will be a big job.
I'll be honest, I think you'll be better off selling the car and finding an auto. Way less work and likely cheaper in the end.
T-Type is offline   Reply With Quote
Old 06-28-2023, 04:59 PM   #3
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Other way around? Who goes from an auto to a manual?
Guessing a 6l80e or th350 wouldn’t be too big of a hassle. Best bet is talk to a local tuner/shop and see what they suggest. Probably need a new driveshaft too plus flywheel.
Bigdumogre is offline   Reply With Quote
Old 06-28-2023, 11:50 PM   #4
Little Walter
Drives: ZL1
If you are going with a OEM 6L90 you are going to need a BCM, TCM (Transmission Control Module), Shifter control panel, Paddle Shifter Assembly, different tranny cooler, different heat exchanger and harness, drive shaft, different rear end gearing. As someone above mentioned you would be better to purchase a already automatic ZL1 and deal with a lot less frustration. It would be easier to put your engine in a already auto ZL than to put a auto tranny in a manual car.
Little Walter is offline   Reply With Quote
Old 06-29-2023, 06:48 AM   #5
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
There is a ton of work for an OE auto. The ECM will need to be tuned for an auto as well.
FasNuf is offline   Reply With Quote
Old 06-29-2023, 09:18 AM   #6
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Yep, and don't forget the rear end it will now expect to see a 3.23 in the tune vs a 3.73.
ZMEnow is offline   Reply With Quote
Old 06-29-2023, 09:26 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I may be wrong here because I'm not a ZL1 owner, but aren't ALL ZL1's equipped with a 3.73 rear gear? The gearing difference would be in the transmissions that the ECU would see, not the rear. The 6L80's in the SS has a 3.23 rear gear. Correct me if I'm wrong.
Old 06-29-2023, 09:35 AM   #8
Little Walter
Drives: ZL1
I think the auto vs the manual is geared different on the rear end also.
Old 06-29-2023, 09:57 AM   #9
T-Type
Drives: Pontiac G8
In my experience that's the only kind of swap I've ever heard asked about. Of course I'm talking all kinds of cars, not just the 5th gen Camaro. A manual gives you more control over the car which improves the driving experience. A lot of driving enthusiasts like that.
That being said, not everyone is the same so I can get wanting to go the other way. Nothing wrong with that. I just have never heard anyone ask about doing that.
Old 06-29-2023, 11:06 AM   #10
gtstorey
This is for drag racing. Auto is faster.
Old 06-29-2023, 11:40 AM   #11
4SFED6.0
4SFED6.0's Avatar
Drives: 1991 Camaro
I did this swap a few years ago from m6 to 6l90e, not that difficult but time consuming. Will need a new dash harness and engine harness to do it correctly, need ecm, bcm and cluster reprogrammed. Obviously pedals and shifter assembly as well. Everything is plug and play once the programming is done. To be done correctly you will also want to change steering column to get the paddle shifter function. The end product works flawless, the only way to tell mine is a swap is to check the vin. Remote start even works.
2011 SS Twin Turbo
Forged LS9/6L90E
Runs 9's
4SFED6.0 is offline   Reply With Quote
Old 06-29-2023, 12:42 PM   #12
gtstorey
You could also consider using a Kilduff shifter assembly if you don't want to mess with the steering wheel swap. It will move all of the shifter to the console area. But I don't know if that will be how you would want to shift while racing.
Old 06-29-2023, 01:44 PM   #13
Trickskier
Native Floridian
Trickskier's Avatar
I have an auto and the only gear ratio available for the auto is a 3.23.
Old 06-29-2023, 01:55 PM   #14
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
You are correct. That is the only gear ratio available for an automatic trans on a ZL1
Bigtime53 is offline   Reply With Quote
