06-27-2023, 08:02 AM | #1 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
quick question on Dealer Installed Options
I'm looking for a vehicle, and not wanting to order new, but my question is on Dealer Installed Options, like the red seat belts, red knee pads, wheel locks, etc. Are these items truly installed by the dealer, like the red knee pads... does the car arrive at the dealership and the dealer removes to current knee pads and installs the red ones? What do they do with the ones they removed? Do you get them with the car?? I'm just curious if I find a car with this option, what my expectations are.
Thanks Last edited by hrpiii; 06-27-2023 at 09:12 AM. |
06-27-2023, 11:29 AM | #2 |
Drives: 2023 2SS Convertible Join Date: May 2009
Technically, you should get any part that the dealer removed back at delivery. Not all dealers offer this, though, and you often have to ask. If the car is sitting on the lot, they might have pitched the parts already. Kneepads are definitely removed and replaced at the dealer. For wheel locks, usually they give you the lock remover with the four lugnuts they replaced with locks nuts in the pack. I think red seatbelts come from the plant if you order them with your car, though. But I could be, and often am, wrong.
-Geoff
'12 2SS RS Convertible - Traded in.
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold! '23 2SS Convertible -Same as above except orange. |
06-27-2023, 11:30 AM | #3 | |
Drives: 23 ZL1 6speed Join Date: Aug 2020
“Straight roads are for fast cars, turns are for fast drivers.”
Gone but not forgotten: ‘17 Camaro 2SS Yellow 6speed |
06-27-2023, 12:28 PM | #4 |
I’ve seen some dealers keep the extra parts. Then I’ve seen some where the parts were sitting in the trunk. It’s a safe bet to ask them about them. I believe in most cases you get both sets when it comes to dealer installed add ons, if they replace existing parts.
Current 2022 Wild Cherrry 2SS; Recaros, NPP, 5 Split Spoke Polished Rims, Satin Black Package
Ordered 7-11-2023 1100: Riptide Blue 2SS, Not Built 2023 Red Hot 1LT RS V6; Sold 2010 VR 1LT RS; Sold |
06-27-2023, 12:35 PM | #5 |
AKA "Beefcake"
Thanks guys. That helps a lot.
06-28-2023, 07:29 AM | #6 |
I did a bit more research. It appears the red seat belts come installed from the factory, if they were ordered with the car. The knee pads are installed at the dealership.
06-28-2023, 08:00 AM | #7 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
My red knee pads were installed at the factory.
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
06-28-2023, 01:36 PM | #8 |
Drives: 2022 Camaro 1SS 1LE Join Date: Aug 2022
Answer on the knee pads is it depends. One RPO is factory installed, red 2F5, white and black are dealer installed. In 2022 the red were also available as dealer installed, WHA. Was vey confusing to me when I ordered. Seat belts are factory only.
At the end of my car delivery video the driver opens the door and you can see the red knee pads. https://youtu.be/J4lnmAeRKm0 |
