06-19-2023, 08:00 PM | #1 |
Oil/filter for built engines
What you guys using for your aftermarket engines?
06-19-2023, 08:23 PM | #2 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
ACDelco PF63E due to larger volume and filtering surface area. It does have the proper check valve in it too. As for oil... clean and change more often that one normally would. Depending on your clearances, you'll likely need something heavier like 15 or 20W. "They" say use higher zinc content.
06-19-2023, 09:17 PM | #3 |
There's a lot of 63s but not so much of the 63E.
06-19-2023, 09:46 PM | #4 |
You want the E for this reason. I split buying a case (dozen) with a buddy.
06-20-2023, 03:57 AM | #5 | |
Drives: 2010 2SS/RS Join Date: May 2010
h
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
06-20-2023, 11:30 AM | #6 |
The PF63F is "fleet-pack", meaning GM/AC-Delco ships 12 PF63E's in a case of 12 (what we did), with thin cardboard between them (NOT in retail/individual boxes to display on a shelf, etc.).
06-20-2023, 12:57 PM | #7 |
Drives: 2014 SS 1LE Join Date: Apr 2014
Wix xp and Valvoline vr1 10w30 conventional on a built 408
06-21-2023, 08:00 AM | #8 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
Valvoline VR1 and ACDelco UPF48R
06-22-2023, 07:16 AM | #9 |
GPI Sales Consultant
For a built high performance motor that you really want to keep track of, we offer a billet reusable filter that you can easily take down and inspected whenever needed to get a good read on the health of your combination. Sure beats cutting open canister filters!
https://gwatneyperformance.com/produ...en-v-lt/ref/3/
Got a question about a GPI product? Feel free to shoot me a message! |
06-22-2023, 07:24 AM | #10 | |
06-22-2023, 07:24 PM | #11 | |
06-23-2023, 01:17 PM | #12 |
They clean with brake clean, carb clean, or dish soap. Good clean, compressed air, and ready to go for the next round.
07-17-2023, 10:39 PM | #13 |
Onyx_Z7 <— Instagram
Drives: 2013 2ss 1le Join Date: Aug 2014
Do these filter better than the reg filters ?
07-18-2023, 06:27 AM | #14 |
No - and that's not really the point of a reusable filter. The reusable filter gives you the ability to easily have a look "inside" the engine - you can get a good idea if you're producing any metal, what type, and what sort of volume, and all of those can be very important indicators for the health of the combination.
