05-11-2023, 08:57 PM | #1 |
Drives: 2013 AGM ZL1, '70 Chevelle 454 Join Date: Apr 2019
Brake Pads
What brake pads would you recommend for a novice on his first track day? Spent the last two nights doing searches and some people like Hawks HP Plus but others don't. According to Hawks website they should be adequate.
2013 ZL1, M6, AGM, CAI, 1 7/8 Kooks Headers, 10% OD Pulley, ID1050 Injectors, 575 RWHP
05-11-2023, 10:25 PM | #2 |
Drives: 2012 SS Join Date: Dec 2021
EBC either yellow or red stuff. yellow is better if you will be doing mostly street driving.
2012 Camaro SS
05-12-2023, 07:20 AM | #3 |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
OEM Brembo’s burnished correctly per your manual are just fine as you are not running any excessive HP.
05-12-2023, 10:01 AM | #4 | |
If anyone can confirm the part numbers below it would be greatly appreciated. Front: 25940447 Rear: 89047744
05-12-2023, 11:04 AM | #5 | ||
Front Disc Brake Pad Set - GM (25940447) Brake Pads REAR - GM (89047744) If you are going to be doing it a lot change your fluid to DOT 4. If you have a temp gun take it so you don't boil the fluid at the caliper. Depending on the track and the day temperatures they could go to 800 - 1000 F. If you come off track after a cool down lap an they are still above 600 I would park it for a while before the next series. |
05-12-2023, 12:33 PM | #6 |
Changing to Dot 4 brake fluid is on the list before I do the track day.
Anyone know if these are the correct front brakes? Amazon shows a different part number but when I do a search on 25940447 this is what shows sup. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
05-12-2023, 12:53 PM | #7 |
Drives: 2013 ZL1 Join Date: Nov 2018
Raybestos ST43 and dot 4 fluid
Call KNS brakes
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
05-13-2023, 10:06 AM | #8 |
I've been running Power Stop brand via RockAuto, very dusty and very noisy but very effective! Paired with blank rotors and DOT4. Roughly 10-15 track days under my belt now (starting as Novice).
I should mention i think my cheap blank rotors have some warping, diving into brakes at 100+ gets a little shaky... |
