04-15-2023, 10:12 AM | #1 | |
Waiting 4 A Point By!
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon Join Date: Mar 2023
Looking for A10 Aluminum Transmission Pan
Has anyone found an aluminum transmission pan option that fits our 10L90E transmission? I am wanting to install a Tilton fluid pump with a remote heat exchanger to supplement the OEM cooler and extend cooling between track sessions.
If there is not one currently made for the ZLE A10, is there any difference between the 10L90 for the ZL1 and truck pan pattern as I might just order a deeper sump pan, machine it down and weld a base with proper clearance. I am also running a Banks iDash for data-logging all the engine/transmission info. This setup might also help in doing fluid changes as well as filtration with a spin-on adapter before the pump. Thoughts? |
10l90e, a10, zle |
