#1 |
![]() Drives: 2019 2SS Camaro LT1 Join Date: Feb 2023
I have a 2019 SS Camaro and my DRL (Daytime Running Lights) on my right side do not work, even the park indicator lights on the right side only, once every 15ish seconds they will flash and thats all. I am originally thought it was just the Brake light but its the whole right side including the front right headlight. Need help
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Just an idea: DRLs and rear park/positon lamps are protected by BCM fuses F18 and F28 in the underhood fuse box, I'd check those first for proper seating and partial continuity issues.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle Terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
#3 |
Not Fuses
I pulled them both out and checked and they are both good, I just found out that its also my DRL right side headlight as well, so the whole entire right side doesn't work but flashes every 15ish seconds
#4 |
![]() Drives: '16 Z06 7 Spd, 2024 High Country HD Join Date: May 2015
Just curious if you checked to see if the problem threw any codes?
#5 |
![]() Drives: 2020 Camaro 2SS Join Date: Jun 2020
I know this thread is nearly 2 years old, but did you ever find out what the problem was and fix it? I'm having somewhat of the same issue, except my front headlight is fine and the rear blinker and brake lights work, but the drl's wont come on on the passenger side. Fuses are fine and no codes are being thrown.
#6 |
![]() Drives: 23 Chevy Camaro Join Date: Nov 2024
So I’m sure I’ll not explain this right but let me try. When I turn my blinker on to turn right (up) NOTHING HAPPENS but the left side blinkers continue to blink even in the neutral position. Does that make sense? It’s not a hyper flash just a regular flash that will not quit. Bulbs are all good.
23 Camaro rs |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SS-RS Join Date: May 2011
Sounds kind of like you might have a problem in the turn signal switch in the stalk/lever. If it still blinks in the neutral position.
#8 |
![]() Drives: 2020 Camaro SS Join Date: Jun 2020
DRL Failure
When my right DRL failed on my 2020 SS the dealership said it needed to be replaced. They wanted over $2k to repair it which requires bumper removal. I’ve noticed in forums it’s more common for the right side to fail. I’ve found replacement OEM’s around $240. I’ll probably replace both sides for equal wear due to labor cost. Estimates online say labor shouldn’t be in the $800 to $1200 range.
| Tags |
| 2019 camaro, drl, help me i'm a noob, not working |
