02-18-2023, 06:59 AM | #1 |
Drives: 2013 ZL1 Join Date: Nov 2018
Anyone running a Spec twin disc clutch?
How is the pedal pressure as compared to stock?
I have a bad hip. https://www.summitracing.com/parts/s.../zl1/year/2013
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
03-12-2023, 08:03 PM | #2 |
Learner of things
Drives: 2013 ZL1 M6 coupe, black Join Date: Dec 2017
Not a spec twin disk, but I have a monster triple and the pedal feel is not much different than stock. I too have intermittent hip problems related to climbing in and out of a service truck multiple times a day for 20+ years.
2013 M6. Cammed, straight piped, 17# boost, E85. Tuned by CHenry Motorsports. 825rwhp @ 6450, 812 rwtq @ 3500. Stock unported blower, stock heads, stock bottom end, stock throttle body. Boost only, no meth, no nitrous
03-12-2023, 09:24 PM | #3 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
+1 on monster lt1 triple here aswell. Agreed feels pretty much stock
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
12-03-2023, 12:06 PM | #4 | |
Drives: Camaro ZL1 Join Date: Sep 2023
12-03-2023, 03:24 PM | #5 |
I do my own work but F&D autocare is a legit shop.
12-03-2023, 03:25 PM | #6 |
You guys with the Monster, do you have any chatter leaving a light or backing up?
12-03-2023, 06:17 PM | #7 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
12-03-2023, 06:38 PM | #8 |
Drives: 2013 Summit White ZL1 M6 Join Date: Mar 2018
Monster triple here. No chatter. Nobody runs a spec on these cars, typically only Monster, McLeod or RPS Carbon.
