02-07-2023, 03:57 PM | #1 |
Drives: 2015 ls, 2015 Silverado LTZ Join Date: Jun 2020
Jack Question
How low of a floor jack do I need to list my stock 2015 Camaro LS?
02-07-2023, 07:20 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Mine is somewhere around 3 1/4” at the front, it’s a low profile though. My car is lowered 1 inch all the way around.
02-08-2023, 05:34 AM | #3 |
02-08-2023, 06:06 AM | #4 |
Anthony S
Harbor freight generic low profile jack will definitely get the job done on a stock height car. My car is lowered on coilovers and I can still get the jack under there, typically I drive it onto some 2x6 planks because its easier, but still... At stock height any harbor freight low profile jack will get the job done.
02-08-2023, 08:43 AM | #5 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
My son's 2014 is standard height, and I can get a normal jack under the sides, and even push it through the front (squishing the rubber trim to reach the closest jack point).
02-08-2023, 09:07 AM | #6 |
Drives: 2011 Join Date: Sep 2017
I can barely get my daytona 3 1/2 low profile jack under my lowered 2011.
