02-02-2023, 02:12 PM | #1 |
NightFuryCamaro
Drives: 2012 Camaro 2SS Join Date: Aug 2019
10L90E Swap: Is it possible, and how would it work?
Recently have been looking into 10L90E swapping my 6 Speed Manual equipped SS. I know it has to definitely be possible in some capacity as GM wouldn't sell the transmission and TCM if it wasn't. I'd just like to know if anyone has any sort of experience in the matter or relatable knowledge regarding an automatic conversion. Would I be able to use my existing ECU, swap out for an Automatic ECU, or go with a drop-in ECU? How would the transmission fit in the car, would it need to be modified to fit in? Seems like a daunting task as far as tuning is concerned, but on the mechanical side it doesn't seem all that difficult. Any thoughts?
Follow me on Instagram and TikTok! @NightFuryCamaro
https://www.instagram.com/nightfurycamaro/ https://www.tiktok.com/@nightfurycamaro |
02-02-2023, 03:13 PM | #2 |
does GM or anyone sell a standalone TCM for that? If so it might be possible. Still might have trouble since the stock ECM will be expecting certain signals that it won't be getting. And re-flashing to automatic operating system would only be worse. If GM has standalone TCM, a standalone aftermarket ECU might control the engine, but you will have to work around a lot of details to make everything else work.
02-02-2023, 04:45 PM | #3 |
I believe it was Janetty racing that posted on here they did some digging and it’s not possible with anything other than the modern LT engines.
ABM #2399 2SS/RS:SOLD
02-02-2023, 11:38 PM | #4 |
NightFuryCamaro
GM sells the 10L90E with a TCM together for $5000. I'd like to think all it would require to hook up to the LS3 is the right adapter, or something of the sort. Don't see why it wouldn't be able to work tuning wise with a drop-in ECU.
02-03-2023, 12:19 AM | #5 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
all I know is that the 10l90e has more sensors and solenoids and isn't compatible with the canbus on the genv but with alot of work theoretically you can get it work with another ECU....meaning 2 ECU's.
not worth it |
02-03-2023, 06:53 AM | #6 |
https://www.camaro5.com/forums/showt...ighlight=10L80
Read janetty racings post in this thread.
02-03-2023, 08:17 AM | #7 |
waiting at the tree
Yes he did post in another thread that it won't work for a variety of reasons.
2010 2SS/RS A6 ZL1 Rims
02-03-2023, 10:38 AM | #8 |
"The SuperMatic™ 10L90-E 10-speed automatic transmission offers a technologically advanced balance of performance and efficiency when matched with Chevrolet Performance’s Gen V Crate Engines"
03-22-2024, 09:51 PM | #9 |
Drives: 2011 2SS/RS Join Date: Feb 2016
old thread but its coming yall. https://www.powertrainswapsolutions.com/
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
03-23-2024, 09:00 AM | #10 |
Fast Cars and Old Guitars
I just bought a Silverado with a 10-speed trans. They have some quirks. They shudder a bit and just feel like they struggle to know what gear they want to be in. In fact, there are CSP's and TSR's on my truck and 6th Gen Camaros. Also, as I understand it, it was a collab with Ford. So you got that going for ya!
I guess I'm not completely sure if we're talking the same tranny but I suspect we are. https://gmauthority.com/blog/2024/03...on-gear-issue/
03-23-2024, 09:09 AM | #11 |
On a positive note, I will say, they have the DFM (new AFM) dialed in. You cannot tell when it's running on anywhere from 0-8 cylinders. No detection of it going in and out of it. While that isn't appealing in and of itself, I don't feel compelled to have it tuned out now. Sorry to change the subject...
10l80e, 10l90e, automatic conversion, automatic transmission swap, transmission |
