01-15-2023, 02:53 PM | #1 |
Lifetime Philly Fan
Drives: 2015 Spring Edition 2SS M-6 Join Date: Mar 2012
Internal Cabin Temperature Sensor
Have a ‘15 Green Flash, I would assume there is an internal sensor hooked into to the AC system.
Where is it? Yes, I know about the one outside. Thanks!! Sent from my iPhone using Tapatalk
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter BBK LT HEADERS 1 7/8” Tune by DynoSteve via SCTx4 Tuner One of 82 GF Ragtops built in '15 out of 811 Total [/SIZE] |
01-24-2023, 10:03 AM | #2 |
Lifetime Philly Fan
So nobody knows anything about this sensor?
My Climate control is weird. With heat on, it blows hot on the right side but not on the left, just regular cool air. I was told by a shop that my compressor needs replacing also because my A/C is weak but fully charged. They said the blend door is fine. Any comments or observations? Anybody at all? Bueller????
01-25-2023, 07:39 AM | #3 |
Drives: 2014 Camaro 1LT Join Date: Aug 2019
How did they confirm that the blend door is fine, because it sounds like you may have the makings of a broken blend door.
01-28-2023, 05:27 AM | #4 |
Lifetime Philly Fan
They said that they listened to it cycle and did not hear anything weird.
No crunching noises or anything. How else can you check it without ripping it apart?
01-28-2023, 08:50 AM | #5 |
Drives: 2011 2SS/RS Join Date: Feb 2016
If the temps dont change both sides its broken. Common issue on these cars. issue really is caused by running max speed on the fan and changing the temps. the cheap design on the plastic gives way causing the inability to change temps.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
01-28-2023, 09:24 AM | #6 | |
It don’t come easy.
Some reading for you. Heater Blend Door Forum Database
02-03-2023, 08:28 PM | #7 |
Lifetime Philly Fan
I ordered the heater hose bypass.
Today, turned it on. Crazy hot air right side, cool air left side. Hoping the bypass helps, I don’t need heat here in Florida. Sent from my iPhone using Tapatalk
03-28-2023, 02:04 PM | #8 |
Lifetime Philly Fan
Ok, clamped the heater hose and I have cold A/C again!!!
I have the bypass hose, will put that on eventually. Sent from my iPhone using Tapatalk
03-29-2023, 11:20 PM | #9 | |
Drives: 2015 Camaro Z/28 Join Date: Jan 2011
03-30-2023, 08:13 PM | #10 |
Lifetime Philly Fan
Thanks! For now I clamped the heater line shut and I have good AC again! I have a bypass ‘u’ hose if I can get at the back hose clamp.
I live in FL and don’t need heat anyways. Sent from my iPhone using Tapatalk
