12-30-2022, 07:01 PM | #1 |
FI Interchiller installed
Finally got around to finishing my FI Interchiller setup. Can’t wait till summer now to really rest it out. It is not a plug and play kit. There is a lot of extras that need to be bought, from lines to fittings, wiring, relays. The fitment from the premade lines from FI could be better. As some of the liquid lines could be longer. Making it harder to zip tie into a good fitting place.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
12-30-2022, 09:42 PM | #2 |
Drives: 2013 AGM ZL1, '70 Chevelle 454 Join Date: Apr 2019
Did you remove the other cooling mods in your signature (afco, prospeed tank, meth, etc.)? I've been toying with the interchiller idea but have been working on other things.
2013 ZL1, M6, AGM, CAI, 1 7/8 Kooks Headers, 10% OD Pulley, ID1050 Injectors, 575 RWHP
12-30-2022, 10:11 PM | #3 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
12-31-2022, 07:18 AM | #4 |
The only thing i removed is the afco and replaced it with the factory hx. You need a hx tank with a chiller, FI recommended the tank from dedicated motorsports as it hold 2 gallons. My meth is more for fueling and less for cooling. I plumbed in a thermostat valve to control flow between the chiller and hx so i don't have to run chiller all the time if i don't have to. Pretty cool valve from pnp tech works.
12-31-2022, 07:21 AM | #5 | |
12-31-2022, 09:05 AM | #6 | |
12-31-2022, 09:18 AM | #7 | |
12-31-2022, 09:22 AM | #8 | |
12-31-2022, 09:25 AM | #9 |
Correct mark. It’s a pretty cool valve. I have it plumbed like this.
12-31-2022, 09:31 AM | #10 |
Having to run all the time is one reason I never considered doing this. What valve exactly is it? Do you have a p/n?
12-31-2022, 09:48 AM | #11 |
https://pnptechworks.com/online-stor...2orb-ports-bcc
They also sell Interchillers just not for our cars.
12-31-2022, 10:04 AM | #12 |
Ok, I thought it was bypassing the chiller. Seems it's supplementing the cooling when ECT is over 100* then when it cools, the interchiller will do all the work.
12-31-2022, 10:20 AM | #13 |
When temps get below 95 it completely shuts down the Hx side.
12-31-2022, 11:15 AM | #14 |
Drives: 2014 ZL1 Join Date: Jun 2009
Badass. Welcome to all year boost weather!
I have a killer chiller on my car and it's the best performance mod I put on it.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
