#1 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
Cyclone Bomb and EV’s.
What’s the over under on EV owners getting stranded when the cold reduces their driving range and strands them this weekend?
Zero stranded EV drivers? 1,000? 10,000? A nice class action lawsuit might be just the thing to restore some sanity. |
#2 |
![]() Drives: '22 LT1 Coupe Join Date: Nov 2021
Whatever the number, 100% of the rescuers will not be driving Camaros. Pot, meet kettle
#3 |
With the right tires Camaros are fine in the snow.
#4 |
Please tell us more about the snow and ice conquerors in the frozen Peach State, and their secrets of success
#5 |
#6 |
![]() Drives: 2023 Camaro 2SS Convertible Join Date: Jan 2022
To be fair, even if the Camaro were specifically the best snow-driving vehicle around, I wouldn't use one to go rescue someone in bad weather. What if there was more than one adult person who needed rescued? Where are you going to put the second? In the back seat? Not if they're over age ten, you're not.
2023 2SS Black/Adrenaline M6 Vert
Previous: 2021 2SS Blue/Gray A10 Vert 2014 2SS Black/Black M6 Coupe 1989 IROC Dark Red |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Her 'ya go. Looks like good EV cold weather info info...
https://insideevs.com/news/626577/wi...ge-loss-study/ |
#8 |
All those quiet EV'z sitting in traffic trying to keep their passengers warm in the sub zero temps
![]() What does this flashing light mean? Re-Charge soon
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust. 665 Crank hp. est. and 660 Crank ft. lbs. est. Never been Dynoed |
#9 | ||
Electrical Engineer
Drives: 2023 1SS A10 Black Join Date: Apr 2022
This is literally me: ![]() ![]() If by "rescue" you mean a tow truck, then obviously... duh. These aren't tow trucks but neither is any car. If by "rescue" we mean drive over there and give people a ride home, then yes, I'll do that in this, in snow. Most people neglect their tire tread design and how it compares with the driving conditions at the time. Some neglect them altogether, entirely. I'll put my SS on Blizzaks up against most people with bald all season tires in an SUV any day. Especially if we're talking about icy conditions, Blizzaks are my go-to. My two fwd sedans have Weathergrip tires, which is a Blizzak tread design on an all-season compound that does really well in snow and ice (not as good as Blizzak given they are harder, but better than any other all-season i've tried). Also, we are talking about extreme cold, not snow. Extreme cold greatly reduces the range of an EV, by a lot. Consider you can get 1/4th the range you thought you had. So "stranded" is just the equivalent of running out of gas. And yes, a Camaro can give them a ride home.
2023 1SS A10 Black H72/C2U/56W/NPP - Daily Driver
1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 64k mi. @ Apr 2026 New Engine @ 22,600 mi. due to dealer confusing bad gas with a bad engine. Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
#10 | |
#11 | |
Electrical Engineer
#12 |
“At 20 degrees, the average driving range fell by 12 percent when the car’s cabin heater was not used. When the heater was turned on, the range dropped by 41 percent, AAA said”
https://apnews.com/article/04029bd1e...f9540a398c12d1 |
#13 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Nope, but they will be driving Gasoline powered F150's Silverados, and GMC's
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | Gen V Hinson Plug Wire Set | BTR 220 Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR6IX-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
#14 | |
Says the guy who lives in Georgia, I want to see you drive your 1LE in 17 inches of snow and say its fine. You've seen your share of plowed roads. Now try one that isn't plowed. And it won't matter what tires you have.
