12-16-2022, 10:55 PM | #1 |
Drives: toyota camry Join Date: Sep 2022
Can you pop in the RS package lower grille insert directly?
Hello, dear Camaro lovers of the forum
Has anyone ever tried to dress-up their non-RS Camaro with this silver lower front grille insert that comes with the RS package? This is the link from GM here: https://www.gmpartsdirect.com/oem-pa...nsert-84112292 I am trying to figure out how easy/difficult to get this on for my non-RS LT1 coming soon. Hopefully I will not need to get the whole front fender off the car for this. Thank you for your input! |
12-17-2022, 07:51 AM | #2 |
Drives: '22 LT1 Coupe Join Date: Nov 2021
There is a button on your link page, "Make sure this part fits your car." Results for 2023 Camaro LT1
12-17-2022, 10:54 AM | #3 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
It COULD fit but the parts/vehicle checker may not be updated yet, or it just won't allow the match because it's a 2022 version and you're checking for a 2023. It DOES show it fits the 2022 LT1, so if the grilles are the SAME, it will fit. OP, you're going to have to find a 2022 LT1 and visually compare the grille to the 2023 model grille. There are two new LT1 verts at a dealer down the street from me and they have what looks like is this insert. I've only looked from the road, as I drive by, but they look more like the part shown (V-shaped) than the photo of the entire grille that's shown in the second post that says it does fit the car. My guess is they changed the RS trim piece slightly for a "new" look on the 2023, but the grille is actually the SAME as 2022. OP you could try checking this way too: spec out a grille only for a 2022 and a 2023 and see it it's the same part #, if it is, the 2022 v-shaped piece should fit.
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
12-17-2022, 12:28 PM | #4 |
If it fits a 2022, it's very likely to also fit the 2023 no matter what the catalog says, since it takes forever to get updated with latest model year fitment data.
...but shouldn't we discuss the outrageous sixty bucks for an ounce worth of ABS plastic, let alone the MSRP of ninety dollars?
12-17-2022, 01:55 PM | #5 |
Thank you! I am more worried about if I need to get my front bumper off to have it installed (in the case there is a retention part need to be put in behind the grille), or I can just insert it directly. Hopefully it is simple...
12-17-2022, 01:57 PM | #6 |
Thanks! I am actually trying to know if I need to take off my front bumper/grille, in order to have this insert installed. It looks like I can just insert it in front of the grille, but there can be a retention part need in the back of the grille...
12-17-2022, 02:17 PM | #7 |
Drives: 2022 2LT RS Convertible Join Date: Apr 2021
The part # you show doesn't have the groves for the grill like mine does. I dropped a Pic.
12-17-2022, 04:03 PM | #8 | |
OP, if you can reach up into the backside of the grille area from underneath, there should be no need to remove the fascia. I'm guessing there's a panel underneath that will pop off with removal of some push-pin type fasteners. I doubt they'd make this part so complicated to install that the entire fascia has to be removed. Once accessed, it's probably held on with a few clips.
12-17-2022, 05:20 PM | #9 |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
Does anyone not consider that putting an RS emblem on a non-RS car makes the car a "fake". That's bad enough, but if the OP ever trades or sells the car, having that non-applicable RS emblem on it could bite him when the buyer or dealer realizes the cra is NOT an RS model that he based his bets offer on.
This is way different than say adding a spoiler or some stripes. No one really buys and puts on this emblem unless they are trying to deceive either a buyer or at least a friend or admirer. Jim G |
12-17-2022, 06:30 PM | #10 | |
Love my Satin Steel LT-1!
Drives: 6-Speed LT-1... Join Date: Aug 2016
2022 SATIN STEEL LT1
6-Speed Man|Carbon Flash Wheels Technology Pkg|NPP|Satin Blk Pkg ZL1 Rock Guards|Red Knee Pad Set PBC LT1 engine built by Debi Lewis |
12-17-2022, 06:50 PM | #11 | |
Drives: Wild Cherry LT1 Join Date: Dec 2016
OP, I looked at my car….it has the part your looking for. From the best I can tell, and has already been mentioned, I think you can disassemble the splash shield / underside of the bumper and possibly remove the standard black inserts and install the shiny inserts. |
12-17-2022, 09:13 PM | #12 |
Your Camaro in the picture probably comes with the Redline package, which gave you a unique lower front grille with a diffrent red insert. Regular LT1 and LT1 with RS package has the original lower grille, and RS package gives 2 silver V shaped inserts on two side.
12-17-2022, 09:14 PM | #13 |
Oh, I am not looking for a fake RS badge to be put on. I just want get those 2 V-shaped inserts onto the two sides of the lower grille.
12-17-2022, 09:15 PM | #14 |
