12-01-2022, 07:55 PM | #1 |
Drives: 2019 2SS Camaro Join Date: Apr 2012
Is my lt4 hpfp failing?
5.5 ms 76 psi low side commanding 2900 seeing 2500?
12-01-2022, 07:58 PM | #2 |
On E65 at your power level, it just looks like you’re starting to get on the edge. What size is your fuel pump lobe?
12-01-2022, 08:00 PM | #3 |
Drives: 21 ZL1 Join Date: Feb 2022
Cam time.
12-01-2022, 09:01 PM | #4 |
So with the lt1 hpfp at 6ms before it starts droping below commanded.
Is the lt4 setup different? stock cam btw |
12-01-2022, 09:07 PM | #5 | |
Injector pulse width will open up as rail pressure drops. 2500 PSI isn’t a massive drop in pressure. As that goes down IPW will climb. Fuel system is always a balancing act. IPW vs rail pressure. On a stock cam, HPFP will run out of steam before injectors. After cam, the other way around depending on commanded pressure.
12-01-2022, 09:42 PM | #6 |
I always thought we were good up to 6 ms ipw. comanded is 2900 lt1 will hold the 2300 untill in the 6s then drop.
50 gph of meth makes up for the fuel system. lol love meth plus it makes power |
12-01-2022, 09:55 PM | #7 | |
You are good to 6 ms. But if you’re not holding commanded rail pressure, your system is heading in the wrong direction. You’re passing the flashing lights for the bridge out down the road.
12-01-2022, 09:59 PM | #8 |
So that is what Im asking at 5.5 its droping to 2500 and comanding 2900. Should be 2900 up to 6 correct?
12-01-2022, 11:40 PM | #9 |
Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
5.6-5.8 is about all I can run on my LT4, If you have a stock LT1 cam its less, so its likely you will start loosing pressure by about 5.5 with lt4 hardware and lt1 cam
12-02-2022, 08:06 AM | #10 |
12-02-2022, 08:13 AM | #11 |
Log HPFP delivery angle.
12-02-2022, 08:35 AM | #12 |
12-02-2022, 08:36 AM | #13 |
12-02-2022, 08:59 AM | #14 |
less than 130* if I remember correctly. That might be LT4 max though.
See below. |
