11-22-2022, 05:59 PM | #1 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Zl1 sway bar upgrade
Ok so I have searched and searched and still can't seem to find my answer and which bar set up to run.
I'm looking to change my Zl1 F/R sway bars to an adjustable bar. I have read that guys run the Hotchkis 22118F on the front and BMR SB054 on the rear both using SPL links. The question I have which I cant seem to find, and the answers I do find are all over the place.What are the spec between the stock FE4 bars which is the ZL1/SS1le to the ZL1 1le bars? Also why aren't guy using the front and rear Hotchkis 22118 kit which it has the F/R. My goal is to match the FEA stiffness or better yet have a little more stiffness that I can adjust. |
11-23-2022, 06:42 AM | #2 |
Im following this discussion now.
I've been planning on adding the BMR nonadjustable rear bar on my car, it's marked at +125% but doesn't state bar diameter and I don't know the stock diameter right now. My driving style is that I prefer oversteer and this ZL1 feels like it understeers more than I like. |
11-23-2022, 08:16 AM | #3 | |
11-23-2022, 08:59 AM | #4 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
There are some really good threads on sway bars here on the form, but you have to dig. Try a search for "sway bar upgrade" and most pop up.
The go to for our cars is the Hotchkis front and BMR rear because their stiffness in relation to the stock bars is very very close, meaning 30/60/90% over stock equally front and back. (I just threw those numbers out) End links are also important as is setting them up when installing them. Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
11-23-2022, 11:10 AM | #5 | |
End links definitely SPL |
11-23-2022, 11:52 AM | #6 |
I've questioned which is 125% over stock, big question there...ZL1? 1LE? SS?
I'm looking at the BMR nonadjustable SB051 |
11-23-2022, 11:53 AM | #7 |
Ill pop under my ZL1 when I get home and measure the bar, the BMR SB051 specs says it's 1.25"
11-23-2022, 03:44 PM | #8 |
11-23-2022, 03:46 PM | #9 |
11-23-2022, 10:09 PM | #10 |
Petro-sexual
ZL1/SS have stiffer bars than ZLE.
11-27-2022, 09:04 PM | #11 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Zl1 and ss 1le have 30mm x.156wall front and 27mm solid rear bars Hotchkiss front bar is 1.25”x .25 wall |
11-29-2022, 06:49 AM | #12 |
11-29-2022, 07:25 AM | #13 |
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10 Join Date: Dec 2017
Does anyone know how the ZLE front and rear compare to standard Zl1? I am keen to investigate if there is any benefit to upgrade from ZLE to aftermarket thx
11-29-2022, 09:32 AM | #14 |
They are smaller...... (I don't know exactly how much, it's in a few threads here)
