11-22-2022, 07:14 AM | #1 |
Anthony S
Which blower is best?
So I am 100% going to be supercharging the Camaro. Hopefully early 2023. Right now Whipple, Procharger, Vortech, Magnuson and all things blower are on sale, roughly 15% or so... On the Whipple kit its currently a $1200 savings...
I was originally going to "budget" supercharge my Car with a torqstorm blower from Mr.Bling motorsports with his intercooler kit...But now that I am looking at the Whipple kits on sale I can't help but lean that direction. The whipple kit is complete with injectors, fuel pump, BAP, pullies, you name it... Its a full bolt on kit minus a dyno tune... The torqstorm kit is roughly $4500 but i still need to buy ZL1 pump, 850cc injectors, tune... so ball park $5500-$6000... I can currently get the Whipple setup for $6500 on sale... Should I just get the whipple? I know it sounds immature but half the reason I am doing this is for the blower noises... Also looking to beat my buddies coyote swapped foxbody mustang with a VMP blower on it on the streets. Wouldn't hurt If I could beat my buddies ZL1 as well... Current power goals are 600-650 rwhp. Probably not going to drag race it since Palm beach international raceway sold out to Walmart distribution.
11-22-2022, 07:16 AM | #2 |
Anthony S
Follow-up question... possibly buying the whipple kit through TSPmotorsports on the layaway program... Anyone have experience with these guys? Should I stay away from this?
11-22-2022, 07:41 AM | #3 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Whipple is a great blower. Can’t go wrong with it. It’s fairly quiet. So if you’re looking for a loud blower whine, that’s not the best pick. A Magnuson with gear drive belt will make some noise. Kenne Bell makes some noise as well.
Lots of good options. We are blessed with this platform to have so many options to add boost. |
11-22-2022, 08:18 AM | #4 | |
Anthony S
11-22-2022, 08:46 AM | #5 |
SoCal Race Team #13
All subjective. Each has its pluses and minuses.
Whipple(2 kits) and magnuson (3 kits) are all proven "bolt in" kits that come with tune (stock like config) Please note, there is no budget option. Your going down a rabbit hole that will cost you 10k. Period. If you can't live with that don't do this, you will just be unhappy with the result.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC Last edited by The_Stache; 11-22-2022 at 08:48 AM. Reason: Reasoning |
11-22-2022, 01:32 PM | #6 |
Drives: 2015 SS Black/Black Join Date: Jun 2016
I would suggest getting a tuners kit and going bigger on the injectors right off the bat. Most kits come with 60-70 lb injectors and you'll have them maxed out around 600-650. IMO with out a cam it's gonna be hard to reach your goals. I'm at 550 running 9lbs of boost and currently waiting to get in the shop to do the cam, zl1 pump, meth kit, flex fuel to get me in the range of your goals.
2015 2SS M6 Stainless Power LT header w/ hf cats, NPP axle backs, ECS Novi 1500 SC, ATI 10% UD, BMR 1.25 springs, trailing arms, and bushings, short thow shifter, Z28 replica rims, BTR stage 2 centrifugal cam, zl1 pump, FIC 1000, and flex fuel
11-22-2022, 01:57 PM | #7 | |
Anthony S
My tuner, Redline motorsports in fort lauderdale, FL and Howard is really good with boost applications. He wants to go e85 for ease of tuning, etc... But i want to maintain street driveability. Howard did mention that I should get a cam but that adds another $3500 to the budget because I am not comfortable doing a cam swap in this car. I built an ls and swapped it before but.. we had issues and I would rather let someone who knows what they are doing install stuff on this car.
11-22-2022, 01:59 PM | #8 |
The kit doesn't come with that so they must be doing a tuners kit and adding those in. The kits only come with 60lb and a bap.
11-22-2022, 03:11 PM | #9 |
Drives: T Join Date: Mar 2015
ECS with the upgraded head unit.
11-22-2022, 08:17 PM | #10 |
Tuner kit, and piece out your own stuff. Torqstorm is limited on power. ECS FTW!! My buddy took advantage of the layaway through them. Paid them off, and it took them 3 months to get him his SC. If it was me... put it on a 0% credit card. Instant gratification.
This is their fuel pump "Custom Fuel Pump Driver Module"
11-22-2022, 09:52 PM | #11 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Whats your guy think on ESS tuner kit , as good as ECS?
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
11-22-2022, 09:59 PM | #12 |
I too going supercharger spring 2023 , been looking at the ESS kit "V3 si with 95mm pully (10 psi ) with my cam , my goal is 600whp. Got the new ZL1 pump already , 600-650whp is all i want to push on the pump
11-23-2022, 06:03 AM | #13 | |
Anthony S
11-23-2022, 09:04 AM | #14 |
Bought torqstorm through TPS lay away- took awhile to get blower due to being shipped to torqstorm for 3.1 pulley other wise straight forward. happy with blower. Making around 650-660 on 93 and cammed. 850cc and zl1 pump but im outta fuel lol
2010 Camaro SS M6: TorqStorm Supercharger. CCP Jam Cam. Speed Engineering 1 7/8 LTs. Catless. Elite Engineering Catch Can. Tuned by Speed Tech Tuning. BMR 1/1.2 springs/trailing arms.
