10-28-2022, 10:14 AM | #1 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Importance of 1LE Canards
Hello all
Tracked my 2020 ZL1 over the course of the summer, and have fallen in love with tracking. Got 18 inch Apex wheels coming for next season for take off slicks and save on cost of rubber. Track buddies and I have a supplier that sells used slicks that were only used for 1 session by pro's, so very high quality take offs. Anyways, I was looking to convert to 1LE front aero, but I'm really against cutting into my bumper. I found that the APR front splitter swaps out with the regular ZL1 splitter, so no need to change my grille. Is there a noticeable affect with the canards? Wondering if the longer APR front splitter will compensate for it. I did pick up a used Anderson Composites 1LE wing. Hoping there's no fitment issues, but it was hard to pass up for half the cost. Couldn't justify getting an OEM wing for how much they cost now. Fully understand that more time behind the wheel is more important than upgrades, but looking long term. |
10-28-2022, 05:20 PM | #2 |
Drives: 1977 Pontiac Trans Am Join Date: Oct 2019
Thought about doing the slick take offs as well and I will pass on some advice from a couple instructors I have talked to. Be very careful with that, and maybe spend another year getting seat time first. Street tires give you clear warnings when they are about to give up the grip, slicks do not, and unless you are very familiar with your car and its limits the point at which they give up can be a surprise. Sorry to hijack a thread just thought I would pass along the info that was given to me. I turned instead to Michelin PS Cup 2's which you can find on facebook marketplace used and perform very well.
10-28-2022, 10:07 PM | #3 |
Drives: 17 ZL1, 03 Z06, 98 Formula, 12 GT Join Date: Oct 2021
I have a 2018 ZL1 that has the 1LE bumper and canards but base ZL1 rear wing. It definitely makes a difference in terms of high speed balance. The car gets looser the faster you go. Is there a noticeable effect? - Yes at 130+.
Having gone down the scrub slick road with a 1998 f-body and 2003 Z06 I would also caution you against doing it especially on a newer car. Cars with highly integrated electronics are very sensitive to tire diameter/width/stagger/compound. You will only make the handling worse with scrubs on something like a ZL1. |
10-28-2022, 10:46 PM | #4 | |
You need to be going around the turns fast enough to make the downforce to then apply it to what you are doing. You will likely be just ripping it down the straights and causing drag with the canards... which is slowing you down overall. |
10-29-2022, 06:44 AM | #5 |
dive planes/canards do have a noticeable effect in high speed braking zones....the front end is noticeably more planted. You can feel the difference as I added them to my '17 ZL1. On street they are useless as speeds aren't high enough to matter.
10-30-2022, 02:17 PM | #6 | |
10-30-2022, 02:24 PM | #7 | |
I did a lot of research on that and the conclusion that I saw was the electronics only freak out when you run square set ups. The take off slicks are something like .2 inches off in diameter compared to OEM, and I didn't see any complaints on the electronics. Biggest complaint was taking 2-3 laps to warm up the tires and loosing a lot of your first session. |
10-30-2022, 02:29 PM | #8 | |
Yeah we really don't have that high speed turns at my home track. Highest speed is something like 80-90 MPH depending on car and conditions. Road America would probably see the most benefit from the canards, but I'd only be going there twice a year max. |
10-30-2022, 02:30 PM | #9 |
How high speed are we talking about? I'd say we only have 1 turn where that applies. Hit about 110 on the straight and brake to about 80-90 for the turn. But on that turn, the rear end is what feels loose, not the front end. Which is why I got the 1LE wing and looking to upgrade to the solid rear cradle mounts.
10-30-2022, 07:00 PM | #10 | |
10-30-2022, 10:02 PM | #11 |
Good to know. Think I'll start with the APR front air dam / splitter and see what the aero feels like. Don't have to take off the whole bumper or drill holes into it, so it's a reasonable compromise.
10-30-2022, 11:43 PM | #12 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
I'd like to hear some details from the 1LE engineer team on when the aero becomes effective. Personally, I think it fees like the canards help plant the front end at speeds of 65/70.
10-31-2022, 09:18 AM | #13 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
They're not completely useless, on a regular ZL1 they will decrease fuel mileage by ~1mpg.
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
10-31-2022, 09:30 AM | #14 | |
Drives: 2023 ZL1 M6 Sharkskin Join Date: Nov 2020
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD 2023 Red Hot ZLE M6 ordered 5/9/23, never built 2022 Shadow Grey 1SS-1LE M6-SOLD 2023 Sharkskin regular ZL1 M6-SOLD |
zl1, zl1 1le |
