08-23-2022, 11:58 AM | #1 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Tire Pressure Monitoring System Receiver
I believe i read it is located in the trunk. Anyone able to confirm and where in the trunk it might be? I seem to be going through GM TPMS sensors every year which could be or am i having a Receiver issue. For the $40 for the receiver i think i would like to give that a shot before spending all that money to have my bead locks taken back off and change out the sensors yet again. Its crazy, the pass rear and front drives quit the same day. This isn't the 1st time 2 went out on the same day and wondering if the receiver is causing it.
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
08-23-2022, 12:44 PM | #2 |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
FYI - it takes all of 15 minutes to change sensors. The tire doesn't even need to come off if they have a hydraulic tire machine. Just break the bead and use the machine to hold the tire down and the sensors unscrew right out.
So hopefully they aren't beating you over the head $$$ wise to change them. |
08-23-2022, 12:59 PM | #3 | |
08-23-2022, 01:15 PM | #4 | |
Sorry man. $80 isn't completely unreasonable but I feel your pain. Hopefully you get it sorted soon. |
08-23-2022, 01:43 PM | #5 | |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
08-23-2022, 02:16 PM | #6 |
my light isnt just on, it is reading Blank for rt rear and front left and will not let me put the car in any PTM modes cause of it so i wont be able to take advantage of the Diff tune i had GM install a few years back.
08-23-2022, 02:20 PM | #7 |
I see. You are getting a TPMS error msg. Why not take all the sensors out and be done with it. If I am not mistaken, the ECU must read all four or none. None sounds like your answer. I wonder if you could just take the receiver out? Should be an easy test.
08-23-2022, 02:28 PM | #8 |
Also, I think the receiver is the long black box located in the back of the trunk right in the middle next to the rear seat. It is all by itself. Check this link out:https://www.gmpartsdirect.com/oem-pa...3503204?c=az0x This is the door lock receiver, but it is similar to the one I pointed out.
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 Last edited by MartinLe; 08-23-2022 at 02:51 PM. |
08-23-2022, 06:16 PM | #9 |
I guess I can try unplugging it and see what happens. Are u sure it's in the trunk? Is it hidden in a side panel cause I'm not seeing it. I do see the ignition receiver behind the rear seat.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive Last edited by IneedAZ; 08-23-2022 at 07:33 PM. |
08-24-2022, 02:16 PM | #10 |
Noticed these sensors on the link below, anybody know if our car will recognize them? Says 433mhz
https://www.alibaba.com/product-deta...277f48e0BYJ1yy
08-24-2022, 02:32 PM | #11 | |
Thank you Al Oppenheiser!
Circuit/System Description |
08-24-2022, 03:09 PM | #12 | |
08-24-2022, 03:10 PM | #13 |
Sorry. I was only guessing about the location.
08-25-2022, 10:47 AM | #14 |
Noticed something interesting yesterday..As i mentioned before i had 2 sensors fail the other day and got the light and wouldnt let me into PTM.(i also tried to read them with my TPMS tool and no reading on those 2, other 2 read ok). Yesterday i went to try a new tune and noticed all 4 sensors show blank on the dash plus the light was lit. The car let me into PTM plus allowed me to adjust the exhaust through the radio like normal.
So with all 4 not showing up car works fine, but 2 not showing you are screwed. That is odd. When i got home i used my scan tool to see if the other 2 failed and they were fine, just not showing up on the dash.
