07-10-2022, 09:35 PM | #1 |
Magnetic Ride Control - Calibration
So some of you may know that I put some BMR lowering springs on FasNuf. Well I knew the Suspension Control Module might need recalibrated because when you lower the car, the sensors get rotated as if the body is in dampening mode and any input from the road from there isn't correctly accounted for by the system. It took a couple tries, but I managed to find a dealer that said they heard of it. The others never heard of it and didn't really care to investigate.
I took the car in early in the morning before the tech got greasy with other vehicles and he connected it to the OBDII. It took about 20 minutes and it was back out in the lot ready to go. He said there was an update to the Suspension Control Module and after he did that, he performed the Trim Height Reset. The Trim Height Reset is basically telling the module that the current resistance at the magride sensors are at neutral height. I didn't expect such a drastic difference in the way the car feels. Probably the biggest difference is in Track mode. The front of the car doesnt bounce like its on stops anymore. I could daily this in Track mode, it's that nice. Touring is more stable over bigger bumps now. The back end of the car would feel pitched up in some bumps and a little unstable in turns. If you lowered your magride car, dont blame the springs just yet, and hold off getting those coil overs until you try the Trim Height Reset and possible update to your module. Expect an hour of labor even though they wont have it but maybe 30 minutes. who knows, maybe i got jipped, but the ride now is worth it.
07-10-2022, 10:01 PM | #2 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Interesting....
I would if this could be done at home somehow?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
07-10-2022, 10:45 PM | #3 | |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
The damping of the suspension would more then likely be written into the firmware so it's stored on an eeprom but the zero and trim should reset by removing the voltage to the module. Disconnect the battery for 10-15min and try it out. |
07-11-2022, 06:54 AM | #4 | |
Unfortunately HP Tuners doesn't give access to the body or suspension control module. Wish they did, we could have all kinds of fun.
07-11-2022, 08:28 AM | #5 |
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White Join Date: Jan 2019
Any details on the update they applied? Interesting.
Levon H. Bone Stock |
07-11-2022, 11:38 AM | #6 |
The technician just told me that when he plugged into the car, and went to do the trim reset that there was an update available for the suspension control module. He updated the module and then did the trim height reset.
07-11-2022, 11:48 AM | #7 |
Chevy Enthusiast.
Thanks.
07-19-2022, 01:22 AM | #8 |
Hello,
Saw your video about this, then found your post. I made an appointment to get mine done. Back end feels loose, been trying to figure out why. Thanks for helping me once again! PS Great looking dog, whats his/her name? |
07-19-2022, 07:23 AM | #9 | |
That’s my wife’s dog Bella. Keep me posted on the results of the appointment
07-21-2022, 02:28 PM | #10 |
can the suspension module be seen/updated through canbus or is it an isolated module?
Fasnuf, any idea what the tech was using for a connection point? |
07-21-2022, 02:43 PM | #11 |
07-21-2022, 04:26 PM | #12 |
He connected his device through my OBDII port.
07-29-2022, 11:47 AM | #13 |
More info
So I took my 2013 ZL1 to the dealer, found out that 2013 ZL1's built after the 1st of August and newer have a reset for the level value. Mine being made prior to August 2013 does not have the ability to be reset. I am checking into updateing my suspension module.
07-29-2022, 01:27 PM | #14 |
Weird, They should've told you if there was a suspension control module update available or not when they plugged into it.
Something seems off. I'd call the parts department and ask if the part number on your vin and my vin are the same for the module. If they are, they're pulling your leg.
