Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 06-04-2022, 04:18 PM   #1
Sparko
Sparko's Avatar
Drives: 2010 Camaro 2SS
Spring compressor for shocks/struts
I was wondering what spring compressors other people are using for suspension springs? I just used the garbage claw one I picked up ages ago to replace a spring on a friends car, and it got me thinking it might be nice to treat myself to something newer and likely easier to use.
2010 Camaro 2SS
2018 Charger GT+
2005 Cavailer LS S/C - Sold
'87 HD FXRT - Wrecked pending repair
Sparko is offline   Reply With Quote
Old 07-31-2022, 02:56 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I use the ones that have a threaded rod going through the two hooks. I think the first time I swapped springs I used ratchet straps. It does not take much to relieve the pressure on the stock springs.
Old 08-08-2022, 02:17 PM   #3
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
I took my struts apart and reinstalled them without a compressor. They really dont have alot of tension on them in these cars.
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
