Old 03-04-2022, 07:27 AM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
So that is what happens...
When you don't use forged internals at 30psi of boost?
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | Roto-Fab CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | Gen V Hinson Plug Wire Set | BTR 220 Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR6IX-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
FlukeSS is offline   Reply With Quote
Old 03-04-2022, 09:49 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
HOLY CRAP MAN!!! That looked like a nitro funny car blowup!! Wow. And the entire truck went off the ground..
Old 03-11-2022, 05:49 PM   #3
FlukeSS
FlukeSS's Avatar
Slowing down the video allows you to identify what blew up.
The engine block is ef'ing toast, and blew off every bolt on attached to it in the process.
