02-12-2022, 08:36 AM | #1 | ||||||
It don’t come easy.
Heater Blend Door Forum Database
Gentlemen,
My goal is to take this particular subject and compile a database of all the threads that pertain to it. I will update the list as I find them. I believe this will be helpful to all who run into this situation with the blend door issue. I’ve been finding quite a bit of info and trust me, it goes back aways, with all types of how to’s on the subject. Stay tuned... These threads are in no particular order. I’m just posting them as I find them. Blend Door Fixed! Heater Blend Door Hack HVAC problems - blend door? AC/Actuator Door Class Action You DO NOT need to remove the windshield to change the heater core. 2013 2 LS No heat but frosty cold A/C Core by/pass A/C Actuator/Door AC warm from drivers vents, cold from passenger vents Blend door “band aid” fix New member to the blend dood club! How to heater core bypass to fix blend door issue Blend door broke but, which one? Only driver side vents blowing hot? AC problems AC/Heater Blender Door Blend door with dash removal side effects Vent Air Temperature Blend door... Blend Door Fixed Please explain the blend door function Finally fixed my blend door Heater core - shutoff or bypass? Bypass install. How to Identify Blend Door Issue? Blend Door AC Repair - Part Number Below are a few videos related to this thread. There are many more you can find by doing a search for camaro heater blend door on YouTube.
02-12-2022, 08:45 AM | #2 |
Nice!!! That will be cool.. Should be a "sticky"..
02-12-2022, 08:58 AM | #3 |
Drives: 2010 RJT 2SS 6 Manual, 1978 Y88 TA Join Date: Mar 2021
Good idea! Thanks.
02-12-2022, 09:03 AM | #4 |
Thank you for your efforts. It is only a matter of time before another new post starts all over again. Much appreciated. I have slowly started searching the forum from the last page & there is so much good information that is not lost but just not looked at.
02-12-2022, 09:25 AM | #5 |
Drives: 2014 Camaro RRM 2SS RS, M6 LS3 Vert Join Date: Aug 2015
Thanks!
Dream it - drive it!
02-12-2022, 10:57 AM | #6 |
Give speed a chance
+1 on the "sticky" idea!
02-12-2022, 02:42 PM | #7 |
It don’t come easy.
ttt
02-12-2022, 04:53 PM | #8 |
Thanks. Yea this is one of those MAJOR deals that seems to always keep popping up, and if it were a "sticky" and inserted in the proper section, I think it would be easier to find and search. Well done..
02-12-2022, 07:08 PM | #9 | |
It don’t come easy.
I’ll try to add in the list the YouTube videos, showing how to’s, as well.
02-12-2022, 07:37 PM | #10 |
Now you are talking!! Fantastic job bro!!
02-13-2022, 05:36 PM | #11 | |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
Thank your for posting this! I just completed this job yesterday! I did it the long way without cutting. The video I am posting helps a lot after the dash removal process that a lot of other videos failed to mention or show! Thanks again! (Not my video)
02-14-2022, 01:07 AM | #12 |
Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Great idea 0stones0!!!!!
03-22-2022, 01:41 PM | #13 |
Drives: 2011 Camaro SS/RS M6 Join Date: Oct 2010
Thanks for taking the time to put this together.
12-25-2023, 04:40 AM | #14 |
Drives: 2011 Chevrolet Camaro SS L99 AT Join Date: Oct 2021
Recently I began to notice that stinky air from outside began to flow into the cabin when the recirculation button was depressed. Usually when I press the recirculation button I always heard a special sound (tzzz). But now it doesn't always appear (from time to time). It is very strange that the car does not allow me to force close the air recirculation door. So I have a couple questions.
-Should I hear the air recirculation door operating sound every time I press the button? Or does the car itself decide to open or close it (maybe outside temp dependent) ? -Is the operation of the fresh air door visible if I remove the cabin filter? In any case, I would like to find the part numbers of the actuators and doors in case of replacement. I found a several numbers but no idea which one I am looking for... Could you please help me to find out... Actuators: GM GENUINE 1574129 (Heater Panel Mode, ALT: 92215209) GM GENUINE 1574128 (Temperature Door, ALT: 92215208) GM GENUINE 13332582 (ALT: 92215207) GM GENUINE 1574042 $14 (Mode Valve Selector, ALT: 92226365) Doors: GM GENUINE 1551251 (Temperature Door, ALT: 92215212) GM GENUINE 1551253 (Defrost Door, ALT: 92215214) GM GENUINE 1551252 (Vent Door, ALT: 92215213) GM 92215211 (??)
2011 Chevy Camaro SS AT L99 / Stock / Daily Driver
1972 Plymouth Barracuda RB V8 3X2-barrel Holley R-4382A/R-4375A/R-4383A (Hamtramck) / Stock / Weekend Driver |
