Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 02-02-2022, 02:12 PM   #1
Mattmarcheski
Drives: 2014 Chevy Camaro RS
Blend Door Help- Southern California
Hi Everyone!
I haven't had this officially diagnosed, but I'm 95% sure the blend door failed in my car. Temperature control no longer works (other than turning on the AC, it'll be slighter cooler) and the vents blow air unevenly.
I plan on keeping my car a longgg time, I don't find it reasonable to pull the dash/windshield every 150,000k for this fix nor do I feel confident doing the hack method myself.
That said, is there anyone that can help with the hack, or is there anyone that can recommend a mechanic that knows how to do it? I'll certainly pay whatever it takes for somebody's time. I live in Los Angeles but can drive just about anywhere in SoCal to get this done. Thank you in advance!
Mattmarcheski is offline   Reply With Quote
Old 02-02-2022, 05:12 PM   #2
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
The easiest fix is to put a valve in-line on the heater hose. Search in the diy section for further advice.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 02-03-2022, 03:08 PM   #3
Mattmarcheski
Hi! Thank you for responding. I’m aware of that temporary fix but I’d still rather pay to have the blend door replaced via the airbox
Old 02-03-2022, 05:22 PM   #4
FASTFATBOY
Drives: 2013 ZL1
Check your freon level, mine was low and it had those symptoms. AIr was hot on the drivers side and cold on the passenger side
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
FASTFATBOY is offline   Reply With Quote
Old 02-03-2022, 09:17 PM   #5
Mattmarcheski
That half hot/half cold symptom only lasted about a day. It now blows air at the temperature that it is outside. Heat doesn't work
