01-23-2022, 10:09 AM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Highest HP LT1 ???? (what CAM?)
Guys I am curious as to what cam was used in the highest HP stock block that you have personally seen??? What basically I am looking for is a naturally aspirated LT1 that makes between 580 and 600 RWHP.
I did a search but came up with nothing that really helps. I had a custom ground cam done that in THEORY should do that but what I am looking for is what someone has actually had personal experience in seeing that number in the REAL world LOL I know LME and others had made as much as 800HP on a motor dyno with LT stroker motors but I an looking to do this 580-600 RWHP with a stock block. i already acquired some very good heads and am currently, running LT2 manifold, LT5 Throttle body, E85 and 2 inch KOOKS headers. Current power level is 475/480 HP/TQ with stock heads and cam. THANKS
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
01-23-2022, 10:17 AM | #2 |
Drives: like an old lady Join Date: Jun 2012
lots of different combos available for those power goals. i think the best thing you can do is get a custom grind from btr or cam motion or something. you'll have to provide information about the heads, so hopefully you have all of that on hand.
2016+ camaro: everyone’s first car
01-23-2022, 10:20 AM | #3 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
01-23-2022, 10:32 AM | #4 | |
https://www.torquenews.com/106/meet-...ated-6g-camaro https://www.camaro6.com/forums/member.php?u=42753
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ |
01-23-2022, 11:56 AM | #5 | |
I think I will go ahead and put the CAM in that I had speced out and see where that falls power wise. My main application is that I road race this car 2 to 3 times a month and also use it as a daily driver. The CAM I speced out is big enough that it requires you to cut .050 valve reliefs in the tops of the pistons. The heads are ONE OFF custom heads from AMP that are ported and milled so that I will be running a higher CR (about 1/2 point HIGHER). Interesting point about this car in regards to road racing it. In TRACK MODE it RARELY sees below 4000 RPM with the A10 which is an incredible trans
01-23-2022, 12:16 PM | #6 | |
01-23-2022, 01:04 PM | #7 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
You'll land around 550-560. Most of the upper powered N/A cars run a large cam, High Ram or MSD and the 103 throttle body. They also push the compression higher to like 13:0:1. The Lt2 is really going to be your main choke point. You may actually end up over camming it if you're not careful since your only raising compression half a point.
01-23-2022, 01:12 PM | #8 | |
01-23-2022, 02:36 PM | #9 |
Well Boys We will see soon LOL Technically the CAM should be good for about 80HP and the heads for another 20HP or so. Of course RARELY does it exactly work out that way but below are some pics of the AMP ported heads and a DYNO of where the car CURRENTLY sits with stock cam and heads.
Using the math above I am expecting 475 (current) + 100 (heads and cam) for roughly 575. AMP predicted around 450 when they did the first set of mods but they were surprised at the 475 number that it actually made. They were also somewhat surprized by the 480 TQ number. Their (AMP) thinking is at LEAST 550 with heads and cam but they tend to be conservative.
01-23-2022, 03:08 PM | #10 |
an msd manifold is the best you can do (under $4500) for an intake manifold that fits under the stock hood. id guess a ported msd would make 15-20 hp peak over a LT2 and also make power longer. tb is a concern at that power level, the 575+ cars seem to be using 103mm tbs.
01-23-2022, 04:14 PM | #11 | |
PLUS these AMP heads flow better than any others I am aware of. I was advised by the tuner that the LT5 TB doesnt have some of the tuning quirks that the 103MM TB does. The 103's especially in BOOSTED applications can exhibit a fluttering issue that you can NOT tune out and the Control Module will reduce the throttle opening to compensate. As far as NA goes this MAY be irrelevant, I dunno.
01-23-2022, 05:52 PM | #12 |
Drives: 2018 1SS 1LE Join Date: Dec 2012
You have the specs on you’re cam ? I made 606 with a GPI/CID heads/cam setup. I would go ported msd at very minimum if you’re running a big cam that needs revs.
01-23-2022, 10:53 PM | #13 | |
01-24-2022, 08:52 AM | #14 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I am at 526 NA on pump 93, yet to do my E50 - E85 dyno run yet.
You can read my mods on signature. I went with the TSP EL 7 cam. It’s a very heavy sounding cam. My heads are shaved. Cam Specs: 23x/24x, .645"/.635", 113 LSA To make the power you want you need to change bore and stroke dimensions. EI: make the piston travel shorter. It’s not cheap to do this. Katech does a nice job at converting a 6.2 to a 427 with 701 HP. https://www.motortrend.com/how-to/16...ed-lt1-engine/ Keep in mind every dyno reads different and the proof in the pudding is a time slip. The dyno number is only a tuning device but an excellent gauge at power levels.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
