12-08-2021, 09:26 AM | #1 | |
Drives: Fast Join Date: Feb 2010
2013 ZL1
My daughter bought a ZL1 to use on her YT channel. She and I are always working on cars so this should be a cool project as it gets some upgrades.
What are some starting mods she should tackle? It will primarily be used at the drag strip, kind of a test n tune thing.
http://www.youtube.com/watch?v=fPvVm...&feature=share
New and improved non-violation sig vid!! |
12-08-2021, 10:12 AM | #2 |
Drives: 2013 ZL1 Join Date: May 2019
headers, pulleys, CAI. And when you decide, go cam, bigger injectors and fuel pumps, E85, ported blower.
12-08-2021, 02:31 PM | #3 |
Dang that's nice!!! Love the burnout!! Most people haven't figured out yet how to do that in a stick car. Kudo's. As my ZL1 friends have done to start, CAI, headers, catback exhaust and a new dyno tune. Then later on they did the pulley swap for more boost, new tune needed, then after that one of them did the e85 kit, new injectors to pick up some more power, new tune again needed, then he was over 650rwhp!! None of them have done a cam swap yet because they are satisfied with the results so far. You don't really need to go into all that to make it a sure fire track monster. Suspension mods and good slicks will do that for you. Good luck you lucky woman!! lol.
12-08-2021, 09:13 PM | #4 |
Thanks guys. Definitely slicks, probably 17". Like the E85 route as its everywhere around here. She is learning tuning so this will be the car she learns on. I'll keep this updated as she goes.
12-08-2021, 09:51 PM | #5 | ||
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Florida, work on Heat Soak, you will rarely know just how much the car has to offer until you drive it in 50 degrees, just make sure its not on those tires.. |
12-09-2021, 12:41 AM | #6 |
Drives: 2013 ZL1 & 2012 2SS Join Date: Nov 2021
Beautiful Car! Just got a 2013 myself!
2013 Chevy Camaro ZL1 Yellow Completely Stock. Brand New To Me
2012 Chevy Camaro 2SS/RS, LS3, GPI SS1 Cam, GPI Cam Kit, LS9 Head Gasket, Upgraded Valley Cover, Upgraded Crank Bolt, Lifter Trays, CHE Trunnion Kit, BTR Platinum Valve Springs, GPI Hardened Push Rods, GPI Phase Limiter, Upgraded Lifters, Corsa Dual Exhaust, Cold Air Intake, Headers. |
12-09-2021, 09:05 AM | #7 |
Some of the first mods will be 160 t-stat and intercooler mods for sure. She'll start out with some cheaper mods first because, well, she doesn't have a ton of money.
12-09-2021, 09:08 AM | #8 |
You still have your SS? My wife has a green 2011 SS she bought new, going to do an LSA kit on it.
12-09-2021, 05:10 PM | #9 |
Nice car! These cars love E85 and some pullies, really wakes them up.
FBO. Cammed. Flex fuel.801whp/741wtq on e85
12-09-2021, 06:34 PM | #10 |
I would say E85 is on the short list for sure. Damn do you have a 2650 to make 800? very nice!
12-09-2021, 11:55 PM | #11 |
Yes Sir! Love my SS and plan to keep it for. Sure! That will be awesome when she does that LSA kit on it!
12-10-2021, 08:54 AM | #12 |
Hope I made the right decision, we ordered the kit from Boost District.
12-11-2021, 05:03 AM | #13 |
Drives: 2013 ZL1 Join Date: Nov 2018
160 thermostat will do nothing, cooling mods aren't needed 1st by a long shot.
Put a cold air intake on and adjust the boost bypass valve this should be good for 30 at the wheels Factory manifolds are pretty good. Mine made 590 wheel with: Cold air intake(same one you have) Adjusted boost bypass valve VMax ported stock throttle body Cat delete 2.4 upper pulley injectors Tune on 93 pump fuel The tires you have on it now suck for anything but road course use, the BFG Comp2 A/S is an amazing tire and the cheapest tire you can buy for these cars. I ran 11.77@ 123 on them and could have went faster with more passes as I will still learning how much they would take in 60ft....mine is also a 6 speed. I live in the deep south, hot AF Nice car BTW |
12-11-2021, 10:40 AM | #14 | |
