dave@hennessey
Old 10-19-2021, 09:56 AM   #1
Soren_camaro
sorenvamps
Drives: 2013 Camaro LS muffler delete CAI
Unhappy camaro stabilitrak
usually I'm driving and when i want to speed here and there ill half throttle and when i come to a stop after that stabilitrack goes on and the thang starts jumping like a Malibu with cut springs (not actually but it jumps) and ive taken it to dealer and tried reading codes all that nothing..
Soren_camaro is offline   Reply With Quote
Old 10-19-2021, 10:58 AM   #2
Rmkuper
Rmkuper's Avatar
Drives: 2010 Camaro SS
This is a common issue with gen5. Moats common issue is a bad battery have it checked/replaced. If that's not it below is a link that covers just about every scenario. It helped me with my issue which ended up being a wiring issue.
https://www.camaro5.com/forums/showthread.php?t=527875
Sent from my SM-F916U using Tapatalk
Rmkuper is offline   Reply With Quote
Old 10-19-2021, 11:37 AM   #3
xstuntman
Drives: 2012 Victory Red LFX
To my knowledge the V6s don't get the heat soak issues the 8s do. It seems like the majority of the time the stabilitrack is the first code thrown out there when its really an electrical slash battery related issue. Not always but usually.
xstuntman is offline   Reply With Quote
Old 10-20-2021, 10:47 PM   #4
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
My experience has been that Stabilitrak warning comes up for a number of reasons. I grenaded an engine and got Stabilitrak warning. I've heard it come up for various mechanical problems.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 10-20-2021, 11:05 PM   #5
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2021 C8 Z51
I had Stabilitrak light keep coming on. I found out that I was missing a body ground. Added a ground from bell housing to the body and all my problems went away. This actually fixed my transmission issues as well.
lewylew is offline   Reply With Quote
Old 10-21-2021, 10:27 AM   #6
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
I had this problem once. Loose spark plug wire caused it.
MIKZ28 is offline   Reply With Quote
Old 10-21-2021, 10:49 AM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
can be a million things. First step pull dtc codes. Very common is throttle body issues. Will throw stabiltrac on, limp mode, bucking.
Greenhornet2 is offline   Reply With Quote
Old 10-25-2021, 05:38 AM   #8
JStampf
JStampf's Avatar
Drives: 2012 Camaro 2SS 2003 Silverado SS
Check spark in plug and wires. the rough ride and stabilitrack are indicators of misfire. I had a plug wire come off just so slightly it was intermittent but had very similar issue.
JStampf is offline   Reply With Quote
Old 10-26-2021, 07:00 AM   #9
AlanRubin
Drives: 2010 LS
I Am on my 3rd one, flagged the stabilitrack, and displayed REDUCED
POWER MODE !
Never got a stablilitrack error for misfires, and I had them for a while, till I
fixed the problem.
AlanRubin is offline   Reply With Quote
Old 10-29-2021, 08:02 AM   #10
SS97N1
Drives: 2011 Camaro SS 2SS
I had this same problem after ring and pinion install and it was the wheel speed sensor.
SS97N1 is offline   Reply With Quote
Old 10-29-2021, 08:54 AM   #11
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Do you have magnetic ride?
FasNuf is offline   Reply With Quote
