08-17-2021, 05:58 PM | #1 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
Z28 CARBON CERAMOC BRAKES ON ZL1-1LE?
Has anyone done this yet? If so, was it worth it? I am wondering about rotor life on the track only.
I would switch back to steel for the road. Or maybe switching back and forth wouldn't be good. I believe I saw somewhere that the rear calipers would have to be swapped out with the z28 calipers also. Or is a better option using the CT5-V brakes and rotors?
08-17-2021, 06:01 PM | #2 |
why? if you want bigger brakes i would probably do the ap racing or essex bbk but what are you trying to achieve?
08-17-2021, 06:47 PM | #3 |
Drives: 2021 ZL1 1LE Join Date: Aug 2010
I have 15 track days on my stock rotors and second set of stock brakes. Right at 1500 track miles.
I run with with some friends that have 5th Gen Z28's and they took off their carbon fiber rotors. Very expensive. They switched to Girodisc and love it. You having issues? |
08-17-2021, 08:55 PM | #4 | ||
Romans10:9-13
I noticed some brake fade at the NCM, but not anything to worry about yet. I know they are expensive, just love having good hard braking. Why did they take the CC off? just replacement cost? going through them quicker?
08-18-2021, 12:21 AM | #5 | |
Drives: 2019 ZL1 1LE Join Date: Jan 2019
Carbon Ceramics won't last as long as the steel brakes. The only advantage is weight. I track with allot of Porsche guys and that's their experience. A good compromise might be the girodisk brakes. Some weight savings but just as good braking power and far less than carbon ceramics. I stay with the stock brakes. |
08-18-2021, 06:14 AM | #6 | |
08-18-2021, 07:31 AM | #7 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Anderson Composite's Sema car had them. As far as I know, the offset is really close, i think a shim is needed between the knuckle and the caliper mounts to get the right spacing to the rotor (or it may be the opposite and it needs to come closer, i know it is a 10mm difference though). Not sure what you'd do with the parking brake, since the Z28 is a manual brake and the ZL1 1LE is electronic |
08-19-2021, 02:37 PM | #8 | |||
Romans10:9-13
08-20-2021, 09:20 AM | #9 | |
Carbon rotors can last quite a long time, but it all depends on how aggressive of a pad you run. We have had track customers go through 3 full sets of factory GM carbon pads before the rotors were smoked, we have also had people smoke rotors after 1 set of aggressive pagid aftermarket pads. Just like steel, wear varies on aggressiveness of driving/pad choice Last edited by Katech_Zach; 08-23-2021 at 08:15 AM. |
08-20-2021, 10:50 AM | #10 |
The 5th Gens didn’t have anything attached to the caliper, there’s a small drum brake set up inside the brake hat. They are not like the older Gens of Camaro/TA’s with a single piston rear disc brake set up.
Orange Krush II
08-20-2021, 01:10 PM | #11 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
https://www.camaro6.com/forums/showthread.php?t=594055
08-20-2021, 01:15 PM | #12 | |
Romans10:9-13
08-20-2021, 01:31 PM | #13 |
Here’s a complete setup but if you need rotors only he might separate.
https://www.corvetteforum.com/forums...-and-rear.html
Orange Krush II
08-20-2021, 08:46 PM | #14 |
AP kit for track is best but really expensive...Z/28 setup CCRs looks great at Cars & Coffee but won't stop any better on track and costs $$$. I would stick with the factory rotors fitted with track pads, Ti shims for the front, GM front air deflectors, and Endless brake fluid. I use Hawk DTC70/60 and can outbrake nearly everything on track.
