Old 06-16-2021, 11:03 PM   #1
MVPxD
MVPxD's Avatar
Drives: 2021 Camaro LT1
Burnout in M6 LT1?
Good evening guys.
So I’m going to the track this weekend. I’m putting some Mickey Thompson’s on which require I burn them out a bit after the water box. Now…my burnouts suck. I’ve been revving up to 4K in 2nd gear then dumping the clutch… burn out a few seconds like 3-4? And the car stalls ….
Why is this happening? Don’t want to embarrass myself at the track. Do I have to press the gas all the way down? This is the only thing I can of I am perhaps not doing? Feel bad on car lol
Traction control is off.
MVPxD is offline   Reply With Quote
Old 06-17-2021, 07:13 AM   #2
FarmerFran
FarmerFran's Avatar
You should be able to do it in 1st, the trick for me was you have to have enough pressure on the brake to not move but little enough for the rears to not clamp. I did enough to spin the wheels a few times, so maybe 2-3 seconds and about 4K Rpm seems right. I sucked at it also, so I quit doing tire warming and just went around the water.
Not sure why it is stalling. ABS or traction/stability control freaking out.
ATCO?
<Insert Cars You Own Here>
Old 06-17-2021, 10:13 AM   #3
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
I hate to admit I've driven a manual all my life and I've never been able to do a decent burnout without messing it up. I either stall or the car will start moving because I let up off the brake cuz I don't want to stall it. I think my issue is I don't like hammering my car, especially the clutch and rest of the drivetrain.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 06-17-2021, 02:45 PM   #4
G8One2
Drives: 2014 Camaro 2SS
Install a line lock. Problem solved
G8One2 is offline   Reply With Quote
Old 06-23-2021, 10:18 AM   #5
s346k
s346k's Avatar
Drives: like an old lady
Originally Posted by MVPxD View Post
Good evening guys.
is there car rolling? if so, i think stabilitrak is the culprit. heel toe it and you won't have an issue. 2nd gear is correct.
2016+ camaro: everyone’s first car
s346k is offline   Reply With Quote
Old 06-23-2021, 02:46 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here is a good vid for you... Enjoy!
Old 06-25-2021, 07:57 AM   #7
6spdhyperblue
Drives: 2SS 1LE
I do second, but with the slightest prep you might be surprised that you don’t even need a burn out
6spdhyperblue is offline   Reply With Quote
