Old 05-30-2021, 09:53 PM   #1
Camaro_Fuzion
Camaro_Fuzion's Avatar
Drives: 2022 Chevy Camaro 2SS Redline
Where can I find used good working parts on the forum?
I'm looking to purchase a used Magnaflow 15092 Exhaust System; Street Series SS Axle-Back for 11-13 Camaro 2SS Where is a good section on the forum to find it?
Camaro_Fuzion is offline   Reply With Quote
Old 05-31-2021, 03:07 AM   #2
AlanRubin
Drives: 2010 LS
I have been getting ALL mine on FB Marketplace, and the Camaro groups.
For $200, I scored ~3000- mile LFX Takeoffs:
Water Pump
Vacuum Pump
VVT Soleniods
Cam Sensors
Coil Packs
Tensioner Arm w/Pulley
$50 for rear ~40,000 mile rear knuckles w/ER brake assemblies, but I used my ER
brake hardware. So, I have a set of those, and back-plates
$200 for ~5 mile 1LE take-offs.
Front sway bar & end links
Front Struts (not on yet)
Rear Sruts
Rear Sway Bar & Links (not using)
Rear toe arms
Outer UCA bushing (not using).
Toe or trailing arm arm POLY bushings (not using)
SS Strut mounts & plates
Front back plates
For $90, I am getting two ~10,000 mile Upper control arms. This guy has the whole
SS rear cradle with LSD 3.27, all the way to the tires; $500, but he is willing to part
it, and I am getting the UCAs. I would buy the whole cradle, but it's too far away.
$35 for Toe/Trailing arms, did not use the Toe arms, since I got the 1LE stuff.
$250 for 2015 factory tires with good tread, and two extra excellent tires.
$250 for winter steelies w/tires
$150 for 5000 mile take-off factory steelies & tires w/caps and lugs
AlanRubin is offline   Reply With Quote
Old 06-01-2021, 02:41 AM   #3
Camaro_Fuzion
Water Pump
Vacuum Pump
VVT Soleniods
Cam Sensors
Coil Packs
Rear Sruts
Rear toe arms
Front back plates
Thanks for the knowledge base. I will do just that in the future. Everyone wants to save money. Having an alternative market place to shop is always great. I think Craigslist is also a thing of the past. With apps like Offerup and the Facebook market place. There's more options to shop and save.
Old 06-01-2021, 03:05 AM   #4
CamaroCarl2012
Drives: 2012 camaro 2ss/rs
There's a members classified section. Sub-forum V8 engine, exhaust, bolt-ons,.... Not a lot of action on there, usually just check every day, if there is a good deal, usually doesn't last long.
CamaroCarl2012 is offline   Reply With Quote
