TireRack
Old 04-14-2021, 09:32 PM   #1
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
question on intercooler and trans cooler placement
So I took off the front nose tonight and started goofing around with the intercooler and trans cooler. The ESS intercooler is massive. Literally takes up all the space in front of the rad. I have no way to mount my trucool 40k trans cooler that wont be partially in front of the intercooler. Thoughts? Think that will be ok?
gunchamp is offline   Reply With Quote
Old 04-14-2021, 09:33 PM   #2
gunchamp
gunchamp's Avatar
The trans cooler will actually be about 1.5" lower than what the pic shows
Old 04-15-2021, 03:32 PM   #3
gunchamp
gunchamp's Avatar
Wheres my ESS auto guys?
Old 04-15-2021, 08:11 PM   #4
gunchamp
gunchamp's Avatar
Well for anyone doing an ESS blower, the trucool 40k is NOT a good fit lol. That intercooler is massive. Took me all night to fab up mounts and end up having to trim the inside of the front nose a good bit to get it to clear. Only covers the top 5" of the intercooler. Should be good to go
Old 04-16-2021, 07:51 AM   #5
RupertPupkin
Drives: 2014 Camaro SS 1Le
There’s a 2nd BOV right? I remember in El’s thread he had to fab up a 2nd BOV valve since he was pushing a lot of air, and the rinky dink one they included couldn’t do the job.
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 04-16-2021, 11:17 AM   #6
gunchamp
gunchamp's Avatar
With the vortech Kris @ jannetty said it wasnt needed. Once I go bigger on the blower, I'll need one
Old 04-16-2021, 06:07 PM   #7
RupertPupkin
Ahh. Thought you got the G3x
730whp: 630Trq
Old 04-16-2021, 08:02 PM   #8
gunchamp
gunchamp's Avatar
Not yet. With my compression i was a little worried of making a bit too much boost with that beast. Its coming, probably G4, but trying to keep my 6L80 alive for at least a summer lol
Old 11-21-2023, 10:41 PM   #9
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
Bringing this back from the dead. Did you ever get the tru cool to work with these intercoolers? I am in the middle of my manual to 4L80 swap to go with my 408 and G4-95.
2010 CGM 1SS
408/4L80E/ZL1
ESS G4
Big Biscuits is offline   Reply With Quote
Old 11-22-2023, 05:29 AM   #10
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I believe he sold the car. Sure hope all is ok with him.
https://www.camaro5.com/forums/showthread.php?t=612504
acutron42 is offline   Reply With Quote
Old 11-23-2023, 09:10 PM   #11
Big Biscuits
Dang, another one gone.
2010 CGM 1SS
408/4L80E/ZL1
ESS G4
Old 11-25-2023, 03:47 PM   #12
Kajun
Kajun's Avatar
Drives: 2013 1SS L99
Not the same cooler as yours. It does a good job of keeping the temp around 180.
2013 1SS/RS L99-GPI VVT SS1 - TSP 1 7/8 headers with Borla Touring exhaust - ESS Tuning YSI V7 - Fore Innovations Dual pump fuel system - 1" BMR lowering springs - BMR toe rods and trailing arms - Prothane rear cradle bushings - Yank 3400 Stall -
Kajun is offline   Reply With Quote
Old 11-26-2023, 04:03 PM   #13
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
I have a Derale cooler. No issues making back to back runs at the track all day long. Plus it mounts right on top of the intercooler.
TheFlyingBananaSS is offline   Reply With Quote
