04-06-2021, 07:27 PM | #1 |
Drives: 2013 2SS/RS LS3 NPP Join Date: Jun 2020
New Spring Advice (see pics)
I'm ready to order a lowering spring package from Phasetek, but unsure if I should get 1" or 1.25" drop. Goal is to improve the look for show foremost, I don't track or race.
Tires are (front) 245 45 20, (rear) 275 40 20. Below are pics of the current gaps. Tempted to get the 1.25's, but concerned about the front settling too much and rubbing...? Thoughts, experiences and advice appreciated! First pic is front, second pic is rear gap |
04-06-2021, 07:31 PM | #2 |
Most of them are not true 1” or 1.25” usually they are not as much
04-06-2021, 07:45 PM | #3 |
I'd go with the 1.25"
I had a little rubbing on the front wheels, the inner plastic splash guard piece. But once you completely rub out the several square inches of plastic it's gone and won't happen again. I love the lowered look. I did 1.4" lowering springs.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
04-06-2021, 07:47 PM | #4 |
Ok cool. I don't want to install the 1" then be disappointed it didn't noticeably drop. Trying to get a more sinister look.
04-06-2021, 07:50 PM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
What are your wheel offsets? If factory offsets you won't have rubbing with either size.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-06-2021, 08:39 PM | #6 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
I wouldn't lower it at all. My ZL1 hits every driveway etc. These cars are lower than they should be already!
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
04-06-2021, 09:21 PM | #7 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Depends on wheel package and the offsets.....and if you plan to upgrade wheel/tire package. I have 20x9 +30 squared on 1" drop and it looks good. Could I go 1.25", probably...but as stated, the lower you go, the more you may scrape/rub. Search some photos of 1-1.25" lowered Camaros....you can kinda get an idea. Good luck.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-06-2021, 09:55 PM | #8 |
Started#gottalovethatblue
I have BMR 1" lowering springs and they're great.
04-06-2021, 10:03 PM | #9 |
Thanks for all the good points. I bought the car in 2020 with American Racing 20" wheels already on it and have never had them off so offsets are unknown at this point. Here is a full pic of a wheel in case anyone recognizes them and has info.
04-07-2021, 07:46 AM | #10 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Here are my gaps with 1” BMR.
Tire sizes are 275/40 and 315/35
04-07-2021, 07:55 AM | #11 |
ZL1s are a half inch lower than the SS and have that integrated splitter, so it's a bit worse for them stock. They do sell marine washers reduce potential damage. I just bought some stainless ones off metric fastener website for $30.
04-07-2021, 08:52 AM | #12 |
Instagram: Sangstah
1.25" is perfect with no rubbing even with an aggressive offset.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-07-2021, 08:12 PM | #13 |
Lowered 1.25 on Pfadt springs. 275/35 front 315/35 rear.
04-08-2021, 06:09 AM | #14 |
Depending on your current whee/tire combo..... you won’t rub
Here’s my setup. BMR 1.4 with 295s in the front and 315s in the back. Only down side with springs is that the rebound if you hit a dip is horrible, and you’ll bottom out more often.
