03-31-2021, 02:18 PM | #1 |
Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
Took a shot at repairing my wheels myself
A little over 3 weeks ago a dumbass ran me into the curb. It happened really quick, it was either get hit or evade into the curb. Either way after, calling a few run repair shops and not getting what I wanted to hear... Mainly a call back, I decided to repair then myself.
My wife was the one who pushed me to give it a shot, so I did. I dismounted the right front tire and moved it to the left because the lip of the tire was chewed up. I busted the tire off the rim lip (we have a tire machine a work) had at it. If I was to do the again I would have left the tires off the rim until I was done. I tried liquid steel to fill in the damage at first Android although it worked, it was a pain to get a uniform fill, and a pain to sand. I looked around the internet at what others had used and found glazing and spot puddy. The glazing and spot puddy worked great. Dried quick and sanded easy. On the ZL1/1LE rims it was easy to block sand, but there is a lot of contouring between spokes. I just took my time and worked the detailed parts by hand. Then I used filler primer to get the fine stuff. After priming and standing 3 times I was happy and hit it with color. For the black paint I used duplicolor HPW104. It's a close enough match. I didn't clear the wheel after painting, well see how it lasts. Looks really close to factory. If the paint wears poorly, I'm going to paint them all in a satin plane propeller epoxy. Either way I'm glad I tried this, they came out great in my opinion.
2014 Camaro 1LE SS/RS THE MISTRESS
03-31-2021, 02:30 PM | #2 |
Disaster averted. Looks great.
03-31-2021, 03:40 PM | #3 |
Drives: 2014 camaro 2ss/rs Join Date: Oct 2020
Looks great! What did you paint the calipers with?
03-31-2021, 03:55 PM | #4 |
Nice work!
03-31-2021, 04:44 PM | #5 |
They came from the factory that way,I think it's part of the 1LE package.
03-31-2021, 05:23 PM | #6 |
Drives: 2012 camaro 2ss rs L99 Join Date: Feb 2017
Looks great, and I bet it feel as good knowing you fixed them.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
03-31-2021, 06:55 PM | #7 |
That's always a great feeling
03-31-2021, 06:59 PM | #8 |
Awesome job sir!!! Nice work...
03-31-2021, 07:15 PM | #9 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Pat yourself on the back...awesome job
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
03-31-2021, 08:26 PM | #10 |
Drives: 2010 2LT/RS Join Date: Sep 2017
that looks fantastic! great job!
04-01-2021, 12:07 AM | #11 |
Drives: 2012 SS L99 Converible Join Date: Mar 2016
Looks fantastic. I really wanted that style of rim but couldn’t find what I thought was worth the price so I redid mine too. When I bought this the rims were curb checked. I took them to a powder coater. Told them I didn’t want black l, didn’t want silver and didn’t want chrome but I did want them cleared. Wanted gun metal or something close. Well, I got flat silver with no clear Couldn’t stand it so I did it myself. At least they don’t look like plastic anymore.
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods |
04-01-2021, 12:33 AM | #12 |
Give speed a chance
Fantastic job and saved yourself some good coin. Next time somebody tries to guide you to the curb don't fool around, put 'em inta da wall!!!
04-01-2021, 04:57 AM | #13 |
Drives: 2010 1SS Join Date: Aug 2015
Where do we send our wheels to for repair?
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
04-01-2021, 05:27 AM | #14 |
Looks really good!
