03-17-2021, 06:33 PM | #1 |
Drives: SS 1le coming Join Date: Sep 2020
tow hook install HELP!!!
the owners manual is useless. On a 2021 SS 1LE front grill, I can see the cut out on the grill but there are no clips to remove the piece to access the tow hook. there are no videos either. Has anyone done it?
thanks in advance. |
03-17-2021, 06:53 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Yeah I was looking at mine and the hook won’t fit through the grill . No cut out on mine nor does a section pop out. Looks like you have to cut a grill fin out to make it work?
03-17-2021, 07:02 PM | #3 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Section pulls out....grab and pull..
2017 1LE Hyper Blue
03-17-2021, 07:08 PM | #4 |
03-17-2021, 07:11 PM | #5 |
Drives: 2017 1ss 1le HBM Join Date: Jun 2020
There should be a small slot type area you can insert a flat head and pry down to pop it out. At least that works on my 2017. I did not pull by hand that hard because I thought I would break it. When I found the spot it popped right out with the flat head.
03-17-2021, 08:30 PM | #6 |
Found it. You wouldn’t even know it was there. Now for a decent looking tow hook. The one Chevy gives you belongs on a battleship
03-18-2021, 05:44 AM | #7 |
Drives: Camaro 1ss Join Date: Nov 2019
well our cars do weight around 4,000lbs... so pretty much a battleship
Follow me on IG for build thread! https://www.instagram.com/tracked_1ss/
YouTube: https://www.youtube.com/@Tracked_1ss FortuneAuto Coilovers! https://shop-fortune-auto.com/produc...ries-coilovers |
03-18-2021, 10:30 AM | #8 |
03-18-2021, 12:00 PM | #9 |
2017 1LE Hyper Blue
03-18-2021, 01:53 PM | #10 |
03-18-2021, 02:07 PM | #11 |
Drives: 2019 SS 1LE Join Date: Jun 2018
I used a plastic trim tool to pry the cover out. I cut it a bit so that I could leave a tow hook in all the time since this is a track toy.
03-22-2021, 07:21 PM | #12 |
Drives: 2020 Camaro 1SS 1LE Join Date: Dec 2019
It was a little tricky to remove. Hopefully, this pic helps. I used a Dremel with a sanding drum to make room for the tow hook.
03-22-2021, 10:20 PM | #13 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
#3702 here as of this weekend.
The ZL1addons tow hook is nice. https://zl1addons.com/collections/camaro-tow-hooks I have the GT4 hook on mine. It has a shaft that goes into the OEM location. The hook goes on/off with a 10mm hex. So you can leave the grille cover on when the hook is off.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-23-2021, 07:58 AM | #14 |
Drives: 2018 Camaro SS Join Date: Aug 2020
4002 when holding the stick in the car. ><
2018 Camaro SS - Hyper Metallic Blue |
