Old 01-01-2010, 11:23 PM   #1
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Camaro5.... Recommend me a Torque Wrench
This will be the first one I purchase. I have read a bunch of reviews of Craftsman on the sears website and it seems like alot of them turn out bad.
What do you recommend
Jeanius is offline   Reply With Quote
Old 01-01-2010, 11:31 PM   #2
shank0668
shank0668's Avatar
Snap on?
Old 01-01-2010, 11:32 PM   #3
We have a Craftsman and it works fine.
Old 01-01-2010, 11:32 PM   #4
TheCaptain
N7 Spectre
TheCaptain's Avatar
Kobalt! Or do they make torque wrenches?
Old 01-01-2010, 11:33 PM   #5
shank0668
shank0668's Avatar
Also have a Craftsman.
Old 01-01-2010, 11:36 PM   #6
TheCaptain
N7 Spectre
TheCaptain's Avatar
Nevermind, Kobalt doesn't make torque wrenches.
Old 01-01-2010, 11:43 PM   #7
shank0668
shank0668's Avatar
Huh? http://www.lowes.com/lowes/lkn?actio...orque%20Wrench
Old 01-01-2010, 11:44 PM   #8
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Snap on?
Had a '58 Snapon torque wrench that we used to reassemble the Cessna 172 that served as a senior project. Hadn't been recaibrated in.. oh 10-15 years and did just fine. Granted that's taboo in an FAA shop, but when we slapped on a newer model one that was reset properly, it checked out just fine.
So in the end, though it may cost and arm and a leg, it's worth it if you have the cash. Otherwise; I'd probably hit up a garage sale, craigslist, or e-bay for a gently used one. Haven't used craftsman professional tools other than a few hand tools, but I know you can't take THOSE back to the local Sears after you heated and bent the torque wrench handle to get at some weird arse nut. :/
Old 01-01-2010, 11:51 PM   #9
Zieke
Camaro Deprived
Zieke's Avatar
Drives: 78 Camaro, 00 Tahoe, 10 Cobalt
Send a message via MSN to Zieke
we always use our craftsman if were tightening to a certain amount.
its always worked great. only thing is it is NOT covered under the craftsman part warranty whatsoever.
My posts are of my opinion most of the time.
I am young and inexperienced. Please don't hate on me for it.
Joined Active Navy: 10-28-08
Zieke is offline   Reply With Quote
Old 01-02-2010, 07:26 AM   #10
cschmidt1956
cschmidt1956's Avatar
Drives: Too Little time to drive....
I bought a nice one at Autozone. Not sure what brand it is but it's very similar to the ones we had in the USAF.
cschmidt1956 is offline   Reply With Quote
Old 01-02-2010, 07:52 AM   #11
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
"Clicker" type are OK but after having one for 25 years or so I suspect I will purchase the "pointer" type next time. The clicker will have you overtorqued if it does not click at the torque setting (for whatever the reason). It DOES happen.
The pointer style will also allow you to read BREAKAWAY torque readings that you can't be read with a clicker. This is important if you have to dissasemble anything that has failed and you want to know why.
JMO.
-Mark.
Stingr69 is offline   Reply With Quote
Old 01-02-2010, 08:10 AM   #12
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I have a Craftsman torque wrench, the kind that clicks and never had any problem with it. One thing to remember, never put it away without turning the torque setting back down to it's lowest setting.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 01-02-2010, 08:11 AM   #13
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
for most newer engines (gm anyways), most all the engine bolts are torque to yield, and the bolts are a 1 time use only,, and when you torque these type of bolts , they use a very small torque to seat the bolts then they are tightened by angle, so you really dont need anything fancy for the initial small torque
example of some of the tty bolts on a LS3:
Camshaft Sprocket Bolt - First Pass 55 lb ft
Camshaft Sprocket Bolt - Final Pass 50 degrees
Connecting Rod Bolts - First Pass 15 lb ft
Connecting Rod Bolts - Final Pass 85 degrees
Crankshaft Balancer Bolt - Step 1 111 lb ft
Crankshaft Balancer Bolt - Step 2 Loosen 360 degrees
Crankshaft Balancer Bolt - Step 3 37 lb ft
Crankshaft Balancer Bolt - (with Flanged Head) Final Step 125 degrees
Crankshaft Balancer Bolt - (with Retained Rotating Washer) Final Step 200 degrees
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence 15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence 80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence 15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence 51 degrees
Cylinder Head M11 Bolts - First Pass in Sequence 22 lb ft
Cylinder Head M11 Bolts - Second Pass in Sequence 90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence 70 degrees
you will need something like this to get the degrees set right:
http://cgi.ebay.com/ebaymotors/OTC-T...ltDomainQ5f100
there are also electronic/digital angle meters/gauges that snap on to your extension and give real accurate degrees for tty bolts
415ci stroker, TVS 2300 Magnacharger, cnc heads, cam, yank ss3200 converter, Kooks long tubes, Bwoody true cold air kit, ZL1 Pump, magnaflow 3" cat-back, lowering springs,BMR control arms and tie rod bars, 3.73 gears, diff mounts, RX can, ADM fuel controller
camaro1 is offline   Reply With Quote
Old 01-02-2010, 11:14 AM   #14
Mr Twisty
Mr Twisty's Avatar
Buy a good Snap On, with a hard case. Keep it clean and in it's case, if it don't get stolen it'll live longer than you.
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Vendor/Sponsorship Info and List for the 1st Annual Official Camaro5 Fest. 1320junkie USA - Texas 1 12-09-2009 11:04 PM
horsepower vs torque zebra Dragstrip and Launch Techniques Discussion 35 09-09-2009 08:26 PM
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 12:28 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 01:28 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 10:06 AM
