02-08-2021, 06:55 PM | #1 |
Drives: 16 Camaro 2SS Supercharged Join Date: Feb 2021
Car wouldn't start after doing pulls
I have a 2016 Camaro 2SS A8 with 37k miles.
List of mods are as follows: Supercharged Magnuson TVS2300 TSP Headers 1 7/8 no cats, DEI heat wrapped K&N Air Intake LT4 Fuel Pumps, HPFP and LPFP Snow Performance Methanol Injection Kit ATI Super Dampner Crank Pulley DSX 230mm Underdrive Pulley for the Blower Borla Atak Axle Back BMR Lowering Springs Car makes around 600 wheel horses on 14lbs of boost and around 617 ft-lbs of torque. A week before my pulls I arced the battery trying to jump start it using reverse polarity as a mistake when attaching the jumper wires. It was a quick touch and go when that happened. We then found out the starter has failed. Replaced it and she starts again. Then, during the pulls my car suddenly won't throttle anymore but instead slowly the RPMs go down. I stopped near an exit to figure out what happened. My temperatures were higher than normal, I had no leaks, there I thought I overheated. The only check engine light I got was from a Cam Positioning Sensor and 02 Sensors which I get sometime an issue happens with the car. After a few attempts on starting, car turned over and died the same minute with a different idle. Then started again a couple more times. I now got my car at the shop that built it, they replaced the positive terminal fuse, and charged the battery. Still we got nothing. They are about to replace the starter again and we will see if that is our problem. If not, can anyone help me please? I am very frustrated at this time. The shop is recommending me to bring it to the dealer if the starter is not the issue. Last edited by 0025_SS; 02-08-2021 at 08:28 PM. |
02-08-2021, 07:32 PM | #2 |
I am sorry but, how do you mess that up?!?!?!?!?!?!?!
02-08-2021, 07:38 PM | #3 |
I don't know if it was too much boost, overheating, electrical or mechanical.
02-08-2021, 07:39 PM | #4 |
02-08-2021, 07:44 PM | #5 |
I was tired and stressed from work. Then the red and green anti-corrosion washers were in the wrong places.
02-08-2021, 07:48 PM | #6 |
02-08-2021, 08:04 PM | #7 |
02-08-2021, 08:04 PM | #8 |
Drives: 1931 Ford 1941&1963 Chevy. 2020 LT1 Join Date: Aug 2020
If it is cranking but not starting it's not the starter.
02-08-2021, 08:06 PM | #9 |
Sounds like the polarity got reversed on something permanently. Hope nothing got fried and its simple. A friend did that on his fox body years ago and had to change pcm, harness and a bunch of relays.
02-08-2021, 08:11 PM | #10 |
02-08-2021, 08:50 PM | #11 |
His car was good after that.
02-08-2021, 09:19 PM | #12 |
Drives: 2019 camaro 2ss Join Date: Feb 2020
14 pounds?? How long have you been running that much boost
2.9 Whipple, CSP longtubes, borla atak, lt4 fueling, dsx aux pump, big gulp, nw 103mm, zl1 rep wheels, Toyo r888r
02-08-2021, 09:57 PM | #13 |
02-09-2021, 07:48 AM | #14 |
While not relevant with regards to your current issue, you should be making well over 600whp if you're running at 14psi
Baby Blue
boost, crank, electrical issues, starter |
