Old 12-31-2009, 04:07 PM   #1
AdnanHfuda
AdnanHfuda's Avatar
Drives: none :(
spoilers? diffusers?
quick question, very noobish but im new to the 'car scene' didnt realy care much about cars till i saw the new camaro. why is a spoiler called a spoiler? and a diffuser called a diffuser?
AdnanHfuda is offline   Reply With Quote
Old 12-31-2009, 04:50 PM   #2
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Well...a spoiler is named that way because if it is too big it can "spoil" the car....
Nothing?
No....
Anyone?
Kyle2k is offline   Reply With Quote
Old 12-31-2009, 05:39 PM   #3
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
Nothing?
No....
Anyone?
He'll be here all night, folks.
nUcLeArEnVoY is offline   Reply With Quote
Old 12-31-2009, 06:16 PM   #4
A spoiler "spoils" the natural flow of air over the car...or something.
Old 01-01-2010, 09:48 AM   #5
Rogue Leader
Iatefiberglassinsulation
Rogue Leader's Avatar
Drives: 2010 Camaro 2SS M6
a Spoiler "spoils" unnatural air movement over a car thats moving.
A diffuser... i don't know why its called that but you can say it diffuses the high speed air coming from under your car back into the atmosphere which is standing still, this creates a suction effect for downforce.
2010 Chevrolet Camaro SS - was daily driver, now toy
2020 Alfa Romeo Giulia Quadrifoglio - Daily Driver
2017 Mercedes Benz GLE 350 - Wifes Car
2008 Chevy Silverado 2500 HD LT 6.0 - Tow Vehicle
1991 Alfa Romeo 164S - Project Car
1994 Volkswagen Golf - Race Car
"Like" my race team on Facebook: http://www.facebook.com/farfrumwinnin
Rogue Leader is offline   Reply With Quote
Old 06-05-2010, 11:38 AM   #6
camaro1324
Drives: none
Diffuser- Can refer to any device that diffuses in some manner.
Spoiler- is an automotive aerodynamic device whose intended design function is to 'spoil' unfavorable air movement across a body of a vehicle in motion.
camaro1324 is offline   Reply With Quote
Old 06-05-2010, 12:10 PM   #7
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
From E-How. com
Purpose of a spoiler is to Reduces Overall Wind Drag
A spoiler is a structure built into the body of car, usually on the back of the car behind the rear window, which is designed to reduce wind resistance by disrupting inefficient airflow. The faster a car drives, the more it must cut through the wind, and the more air resistance the car experiences. Generally the more surface area that is exposed to the wind, the more drag the car will generate, meaning the added surface area of the spoiler adds some drag. On the other hand, a spoiler diffuses airflow in such a way that drag is reduced on other areas of the car, resulting in an overall reduction in drag and increase in aerodynamic efficiency.
Wing-Shaped Spoiler
The term spoiler is commonly used interchangeably to describe an aerodynamic enhancement, which is a true spoiler, and a wing shaped extension, often seen on sports cars or race cars. The wing shaped extension functions differently from a standard spoiler. It uses airflow to create downward force on the body of the car to increase friction and traction, thereby allowing the car to drive faster and reducing the tendency for a very fast vehicle, such as a drag racer to lift up from the ground. Unlike a normal spoiler, a wing type spoiler creates a net negative of in terms of wind drag, so the efficiency gained in terms of traction must exceed the extra wind drag in order for the spoiler wing to yield a net benefit.
Decorative Spoiler
While the standard spoiler and wing spoiler are aimed at increasing driving efficiency, many car spoilers are installed as a matter of aesthetics. Many modern vehicles come with spoilers aimed at making the car look stylish or sporty while yielding little or quite likely negative wind drag efficiency. Automotive enthusiasts sometimes install their own spoiler modifications. Such modification is much more likely to result in lower aerodynamic efficiency, speed and acceleration than it is to result in an increase in performance.
And from Bodykits.com
Diffuser - A diffuser is a carbon, plastic, urethane or fiberglass peice that mounts on the rear bumper over or near the exhaust tips. A diffuser helps air travelling underneath the vehicle join air flow rolling over the top of the vehicle in a more aerodynamic manner.
Spoiler - A spoiler is an aerodynamic device attached to an automobile whose intended design function is to 'spoil' unfavorable air movement across a body of a car in motion. This can result in improved vehicle stability by decreasing lift or decreasing drag that may cause unpredictable handling in a car at speed. Spoilers are often fitted to race and high-performance sports cars, although they have become common on passenger vehicles, as well.
The Bird is the word!
Camaro Dove Tail Spoilers Compilation daphatgrant Cosmetics and Lighting Modification Discussions 473 07-11-2025 09:07 PM
Rear Spoilers at SEMA DocHolliday Cosmetics and Lighting Modification Discussions 52 11-16-2009 06:21 PM
Where is the High Wing Spoiler??? Or any other different spoilers. Mohrg Beast Cosmetics and Lighting Modification Discussions 41 10-27-2009 08:58 AM
Hoods & spoilers? toehead93 Cosmetics and Lighting Modification Discussions 0 06-29-2009 03:55 PM
