12-09-2020, 08:53 PM | #1 |
Drives: 2013 Black SS/RS Join Date: May 2017
Tail light indicator lamp
I have noticed this indicator on driving down the highway in broad daylight several times including today.
It comes on when I start the car in the garage and normally goes off as I back out. It is on when driving at night when headlights are on. I have not added any harnesses or other wiring to my 2013 2SS/RS car. |
12-09-2020, 11:24 PM | #2 |
Is it flashing or just solid on? I have read some others here having this issue as well a while back.
12-10-2020, 06:26 PM | #3 |
It's just on like it is when it's supposed to be on. I've been thinking about going by a store or somewhere I could circle around to see if the tail lamps are actually on.
12-10-2020, 07:03 PM | #4 |
Check your bulbs, you might have 1 going or is out..
