Go Back   Chevrolet Corvette Stingray C7 Forum > Marketplace > Commercial Classifieds Marketplace > Wheels / Tires
Old 11-06-2020, 05:09 PM   #1
Apex Wheels
Apex Wheels's Avatar
Drives: Camaro Z28
► APEX | Flow Formed Lightweight Corvette Wheels - Built to Perform
APEX Flow Formed Wheels
For over 10 years, APEX has been the go-to wheel for enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 and EC-7 designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer FL-5 and SM-10 designs provide a step-up in strength and true race wheel features like I-beam spokes and reinforced lips.
➡︎ Perfect fit without spacers
➡︎ Made to work with big brake kits
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Order Now
C5 Fitments / C6 Fitments / C7 Fitments
Designs & Finishes
EC-7 - 18" / 19"
Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Available in a single high-clearance face profile to clear stock and aftermarket brake setups with plenty of breathing room.
SM-10 - 18" / 19"
Modern design with reinforced lips and I-beam spokes. The SM-10 spokes were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Knurled beads are added to reduce tire slippage and maintaining a true balance. Available in Profile 3 (deep concavity).
Order Now
Fit Matters
The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments ranging from 10" to 12.5" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each generation of Corvette. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment?
100% OEM Compatibility
No need to change your lug nuts, center caps, or TPMS sensors. All APEX Corvette wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug nuts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x120.65 Corvette wheels use a 70.3mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black APEX center caps, but you can also snap-in your factory C6/C7 Corvette caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
Brake Clearance
If the spokes or barrel of a wheel can’t clear your brakes, the wheel can’t be used at all. We’ve made sure all of our flow formed wheels clear OEM steel brakes spacer-free when the correct fitments are used. With many applications, even big brake kits will clear spacer-free. The 18" SM-10 wheels even clear the massive OEM carbon ceramic brakes. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX flow formed wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX Corvette wheels with a 5x120.65mm bolt pattern are purpose built featuring a 70.3mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our Corvette wheels to be interchangeable with the OEM cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
Learn more
APEX Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Learn more
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively.
All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
Order Now
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
Apex Wheels is offline
Old 06-10-2021, 05:20 PM   #2
Apex Wheels
Drives: Camaro Z28
New finishes alert!
Our popular SM-10 wheels for widebody C6 and C7 cars will now be available in Race Silver and Satin Bronze. These will be offered in 18x11" ET38 and 18x12.5" ET52 for the first run.
10% pre-sale is live and will run until they are set to arrive in September. Head over to the site now to reserve your set: https://www.apexraceparts.com/shop-b...-widebody.html
Old 10-19-2021, 07:02 PM   #3
Apex Wheels
Drives: Camaro Z28
Lots of EC-7 and SM-10 Corvette wheels in stock now with many more coming in the next few weeks. Things are already starting to sell out quickly so act now before they're gone!
Old 04-29-2022, 06:24 PM   #4
Apex Wheels
Drives: Camaro Z28
Don't forget, lots of flow formed wheels available in our tax season sale going on now!
Put that refund to work with our Tax Season Sale ongoing now. Save up to 20% off a huge variety of in-stock fitments.
Buy Now
The Discounts
Sprint Line EC-7RS: 10% off
A Classic Reborn. The EC-7RS is a re-imagined and optimized version of our classic mesh EC-7. With the stiffest spokes of our new Sprint Line Forged offerings and a new Sprint-Spec inner lip, now is a great time to make up for missing our recently closed Group Buy and pre-order a set of these new wheels.
APEX Flow Formed: Up to 20% off
Our most popular wheels. Our original Flow Formed Evolution line SM-10 designs are heavily represented in this sale. Every diameter we currently produce and a wide array of sizes and offsets are discounted bringing even more value to our most affordable wheel lines.
Buy Now
Ready to Ship
The majority of these wheels are in stock and ready to ship. Don’t let the supply strain struggles wrought by COVID delay your build and cost valuable track time. Get your wheels on the way now to make planning and tire sourcing easier than ever.
The first 19” Corvette EC-7RS wheels have not yet arrived and will ship out as soon as the first production shipments of these wheels arrive at our warehouse.
Old 07-19-2022, 06:59 PM   #5
Apex Wheels
Drives: Camaro Z28
Plenty of SM-10 wheels in stock and on sale, snag a set today for beautiful summer cruises!
Old 08-17-2022, 07:21 PM   #6
Apex Wheels
Drives: Camaro Z28
Does your car have APEX Wheels on it and you've always wanted some professional photos taken of it? Or perhaps are you in the market for wheels and local to the Bay Area?*
We are looking for volunteers who fit in the above categories to come hang out with us for a couple hours and take photos. You will be compensated for your time with discounts on future purchases a firm handshake from one of our employees, Joe (don't worry, he usually washes his hands).*
Our only criteria at this point is you must be willing to drive to us in Pleasanton, CA & surrounding areas. If you are interested, please fill out this form and we will contact you to move forward!
https://www.apexraceparts.com/suppor...hoot-volunteer
Old 12-15-2022, 05:35 PM   #7
Apex Wheels
Drives: Camaro Z28
Gear Up Now for the 2023 Track Season and Save BIG with our SM-10 Clearance Deals
Our year-end Clearance Sale starts today! If you didn't get new wheels for 2023 during Black Friday, now's the time.
Fair warning: when the inventory levels of certain fitments and finishes become too low, we will remove them from the sale, so... Place your order early to get the best selection.
Buy 3 SM-10 Wheels, Get One Free!*
for Camaro, Corvette, Mustang, Tesla, Lexus
*Just add four wheels to your cart to see the savings.
While Supplies Last – First Come, First Served
