10-30-2020, 04:00 AM | #1 |
Drives: Camaro 1LE Join Date: May 2018
About ready to call it for year
Well it's about that time when some of us tuck the toys away unfortunately. All it takes for me is MoDot throwing down salt and that's that. Doesn't matter if it gets warmer a week later or not. My car will sit until late next spring so the rain washes that crap off the roads. We are flirting with freezing temps already and so I'm anticipating messy salty roads sooner than later. I would really like to get the car out one more time but it is pretty much prepped for storage other than pulling the battery out.
So who else is either done or about done driving their Camaro for the year? |
10-30-2020, 05:27 AM | #2 |
It don’t come easy.
I figured 2 more weeks. She’s going out this weekend and as far as I can tell the next weekend as temps are back up to the 50’s. We had snow here last weekend but, all melted off with no salt down as of yet. Everyday I can drive just makes for a shorter winter.
10-30-2020, 05:34 AM | #3 |
Drives: 2013 2SS/RS 1LE Join Date: Jul 2020
In Maryland we have a few more weeks before temps start to drop. hoping to hit one more Cars and Coffee
2013 2SS/RS 1LE, 233/242 cam w/ supporting mods, TSP long tubes w/ test pipes to NPP. Rotofab intake. BMR 1", 480whp 439tq.
10-30-2020, 06:10 AM | #4 |
Drives: 2012 Camaro SS Convertible 6MT Join Date: Jun 2020
Mines been sitting in the 3rd stall for two weeks now. Will take it for my mgw shifter install in a week or two but that is probably about it.
10-30-2020, 06:36 AM | #5 |
All tucked in. Winter sucks, esp in Michigan.
Still got a half tank of premium, wish there was a way to drain it out - I tried, but can't get even a small diameter tube to fish into the tank. Everyone use Sta-Bill, or fill it up, or what. I don't like the idea of a full tank of 5-6 month old gas. |
10-30-2020, 06:47 AM | #6 |
Drives: 2012 Camaro SS Join Date: Jun 2019
I tucked mine away for the winter last week, we had frost earlier this week so I think it was a good call.
For what it's worth hesster, I run the tank as close as I can to empty, then add a bottle of fuel stabilizer and fill the tank right before I store it, I haven't had any fuel related issues and I've been doing it for 8 years. Just my experience.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
10-30-2020, 07:10 AM | #7 |
Drives: 2012 2SS INFERNO ORANGE Join Date: Apr 2015
oil changed and put away last week in september for me.
10-30-2020, 07:14 AM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Mine gets put away...sorta. If the streets are dry and the sun is out.....I'm cruising. Life is too short.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
10-30-2020, 07:26 AM | #9 |
Do you guys do anything else? Disconnect battery, other maintenance? Full bottle of stabil?
Thanks - first winter with a summer toy. |
10-30-2020, 07:36 AM | #10 |
nope i do nothing..just start if for a minute or two every 4 weeks...i think the valve springs sitting for long periods compressed cant be too good.
10-30-2020, 07:53 AM | #11 |
10-30-2020, 08:09 AM | #12 |
Always on a battery tender, and jacked up somewhat to take the full load off of the tires. Don't ever fully unload the chassis tires/wheels, as it is not good on the bushings and esp if you have Coil Overs. Newer tires prob don't flat spot, but I make sure of it.
10-30-2020, 09:29 AM | #13 |
10-30-2020, 09:56 AM | #14 |
Loving your new avatar. I haven't seen that picture in ages.
I feel for you guys that have to do this every winter. But at the same time you guys get to experience that rush of excitement every spring. Also, the reduced wear and lower miles is a positive. I have noticed a lot of you guys that tend to use the winter for making changes to the car.
