10-11-2020, 08:12 PM | #1 |
Drives: 2011 Chevy Camaro LS Join Date: May 2016
Overheating
My car keeps going to 258 when I’m driving but it drops to 212 210 whenever I stop.
I got the message on my dashboard about my car overheating , I couldn’t pull anywhere to the side ,but when I was about to,the needle went back to normal. The fans are working properly. When I got home I pop the hood and heard the fans working. All of them. So I don’t know what it would be. Any recommendations? Going to a mechanic tomorrow. But I want recommendations to see what it is before I hit the mechanic. Because mechanics wanna make money and they’ll tell you lies just to make money. Specially on this Covid situations. sy |
10-12-2020, 06:44 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Coolant level good? Maybe bad thermostat.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
10-14-2020, 03:34 PM | #3 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
10-15-2020, 08:32 AM | #4 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Check for air in your coolant system.
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
